Factory deck does not play CDR's well
Old May 30, 2003 | 06:04 PM
zland's Avatar
zland
Sport Z Magazine
Default Factory deck does not play CDR's well
Has anyone else noticed that the stock Stereo/CD player does not play many CDR's without skipping. My regular CD's play fine. My CDR's play fine in my other car but about 50% of the CDR's skip in my Z?
Seems odd to me my old CD player in my other car plays CDR's fine but my 2003 350Z skips with them....
Jeff
Old May 30, 2003 | 06:14 PM
2003z's Avatar
2003z
mine plays cd-rs and cd-rws fine. my S-10 won't play cd-rw at all
Old May 30, 2003 | 06:27 PM
alphared's Avatar
alphared
yep plays fine for me too. maybe your cdr's are dirty. try cleaning them and see if it skips.
Old May 30, 2003 | 09:22 PM
ares's Avatar
ares
Veteran
man I am all about the cheapest stuff possible, ussually fuji CDs for 3$(50 pack).
NEVER had a single CD skip.
Old May 30, 2003 | 09:34 PM
zland's Avatar
zland
Sport Z Magazine
Thanks guys for trying to help me out. Just so you know:
1. CD's can be brand new, play in home deck or other car or portable CD player without skipping but skip in Z. Then, i take it back to other decks, it does not skip.
2. Tried different type of CDR's including Sony etc, still skips.
3. Oddly, some CDR's play fine, others not very well. Yet all play in other decks without skipping....
Nice to know you guys are not having problems. I wonder if this is a warranty issue? I am thinking of buying a new Eclipse head anyways just to get a better deck and to get rid of this problem but i would prefer not to spend the money. I replaced everything already but the head, stereo already sounds great...
Jeff
Old May 30, 2003 | 09:41 PM
Silver Bullit II's Avatar
Silver Bullit II
Default zland,
The laser on your Z's CD player is misaligned and will need to be replaced, that is, the entire unit.
JMs in TX
Old May 30, 2003 | 10:16 PM
zxsaint's Avatar
zxsaint
Fairlady Stalker
Actually the FUJI CD-R's are some of the best ones. They're pretty much all Tayo-Yuden discs manufactured in Japan. TDK also has some TY discs.
Stick to those and you'll be fine. Also (optionally) when burning music for the car, its best to keep it below 16x to keep errors minimal.
I've got over 20 fuji cdrs that work great... haven't skipped once.
Old May 31, 2003 | 10:41 AM
dbpoet's Avatar
dbpoet
Ocassionally I have the same problem as Zland. But the strange thing is that the first tracks (1-4 or 1-5) play great but then they'll start cutting out. All the CDR's that do this also play great in all my other players. I've tried cleaning and resurfacing them and they do the same thing. It only happens on CDR's not pre-recorded CD's.
Old May 31, 2003 | 08:42 PM
ares's Avatar
ares
Veteran
I used maxtor, and sony(and imation, NEVER gotten an imation to work), both worked sometimes and not other times in my last car, it was wierd, it always went by the pack, not by the CD, every CD out of 50 in one pack wouldnt play, and every one in another pack would.
fuji is the only one that has NEVER given me trouble, didnt know they were good, figured they sucked cause there sooo cheap at compusa.
Old May 31, 2003 | 09:04 PM
n8vz's Avatar
n8vz
Default no skip with Memorex
No skip with Memorex CDR. (as far as i can tell)
Although, my buddy who is a home audiophil sat in my car and when i started the stereo,the first thing he said to me was.."that is a CD-R you are playing in your stereo." I'll try playing an original CD and see if i can hear the difference.
BTW,
I have the non-BOSE system and personally the Stereo is my Z is the worst Car stereo i have ever had. But that was what i expected anyways. didn't buy for car for it's sound system.
Old May 31, 2003 | 09:55 PM
x2k6's Avatar
x2k6
Did the Cd-R have a label on it?
Old May 31, 2003 | 09:59 PM
zland's Avatar
zland
Sport Z Magazine
what type of label are you looking for on the CDR?
Old May 31, 2003 | 10:08 PM
x2k6's Avatar
x2k6
Like a Cd stomped paper label on the CD-R cause that might mess up the cd player.
Old May 31, 2003 | 10:15 PM
zland's Avatar
zland
Sport Z Magazine
Really, are you joking? I use them on about 50% of my CDR's. How can something on the other side effect the playing/reading of your CDR?
Old May 31, 2003 | 10:49 PM
x2k6's Avatar
x2k6
Im not sure in your Z, but in the my max the owners manual its says Do not use the following Cds as they may cause the Cd player to malfunction.
>Cds with a paper label
Old May 31, 2003 | 10:56 PM
zland's Avatar
zland
Sport Z Magazine
wow, I will check, that would be amazing if it was the rpoblem, thanks for thinking of a detail I would have NEVER thought of..Jeff
Old Jun 1, 2003 | 05:49 AM
nlauri's Avatar
nlauri
I have the Bose and it plays original cds fine but cdr's sound terrible. I didn't have a problem with skipping but most of the songs sounded horrible and this is after replacing my speakers. So I stick to my mp3 player which sounds great.
Old Jun 1, 2003 | 05:50 AM
n8vz's Avatar
n8vz
CD labels (e.g. Stickers). can off set the balance of the disc while it is spinning.
Old Jun 1, 2003 | 07:20 AM
Rahtok's Avatar
Rahtok
Try burning them at a lower speed. A lot of CD Burners have trouble tracking well at higher burn speeds, and lowering the burn speed will allow for a bit more tolerance on laser alignment on the part of the players.
Media has much less to do with this than actual burner and speed. If you're having problems, switch to a quality media, and buy a plextor.
Old Jun 1, 2003 | 08:16 AM
dlt1cy's Avatar
dlt1cy
i would bet money that it's the paper label. i had the same problem at first. i determined it was only the ones with the paper labels that skipped.
