is this a ground problem
Old Dec 26, 2007 | 06:05 PM
sirfatty's Avatar
sirfatty
Default is this a ground problem
OK here we go
At my battery i am putting out 12.6 volts car off
At my amp i am getting 12 volts car off
Connected to all of my cars wires my remote turn on that is plugged into my brothers amp in his car is getting 1.6 volts(amp wont turn on)
Connected to all of my brothers wires the same remote wire that has not changed is getting 13 volts and (my amp works 100 %)
So question is this a bad ground.
If so where do i ground at. my options are some what limited because of deadening that was already installed.
Old Dec 27, 2007 | 07:22 AM
DVFlyer's Avatar
DVFlyer
Speed of White
A ground is easy enough to test. Find any bare metal. If there is deadening in the way, cut a piece out. Be sure to grind away any material/ paint etc.
Old Dec 27, 2007 | 08:52 AM
2boosted4u's Avatar
2boosted4u
where are you mounting the amp?? what he said ^ bare metal or if your goin under the seat ground to the bolt that holds the seat down
Old Dec 27, 2007 | 09:13 AM
doug's Avatar
doug
Originally Posted by sirfatty
OK here we go
for my ground i sanded down the baby seat hook in the trunk behind the passenger seat
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
