Bose Speaker wire path/direction...
Old Jan 12, 2008 | 10:35 AM
A.E.S.S.'s Avatar
A.E.S.S.
Default Bose Speaker wire path/direction...
Hello guys, i'm no guru here but I need someone's advice about the wiring path/direction of a Bose system (07/Touring) w/out navi. I am determined to do my own installation all the way through but not quite sure how the existing speaker wires travel. I will use an after market amp & components and I would like to keep existing component speaker wire (don't really have to much wattage going to Alpine SPS-171A's). Here is the question because I have read in other threads about the stock Bose Amp Location but I did not find anything about whether or not ther travel of the speaker wires is conventional. By conventional I mean from head unit to Bose Amp and from Bose amp to speakers or is it complicated like from Bose headunit to amp & Bose headunit to speakers where in some complicated way it gets amperage back to the headunit to disburse? Any help from you pros will be greatly appreciated!
Old Jan 12, 2008 | 08:05 PM
Zridder19's Avatar
Zridder19
I literally just finsihed my install of a full system with the stock Bose crap. Ive been doing stereos for years now, and that was the biggest pain in the *** I've ever dealt with. You are better running your own speaker wires if you can do so. If not I will give you the diagram for all the different colors you will need to deal with. Good luck.
Old Jan 12, 2008 | 08:15 PM
Spork's Avatar
Spork
Better to just run your own, new wires. It'll take a few more hours, but it allows a much cleaner, newer install.
Old Jan 12, 2008 | 09:45 PM
A.E.S.S.'s Avatar
A.E.S.S.
Thanks man, I appreciate your help, maybe after seeing the diagrams I might opt to re-wire it myself. It just looks pretty involved to go through lever in the door and feed the wire through. I'm just so busy now but like I said maybe I will give it a shot.
Old Jan 13, 2008 | 12:34 AM
PoorG35's Avatar
PoorG35
just use the bose wires, not worth it if using basic comps.
Old Jan 13, 2008 | 01:01 AM
PoorG35's Avatar
PoorG35
anyway if you want to see the diagram of the bose amp schematics go here:
hxxp://www.350z-tec h.com/forums/index.php?act=Attach&type=post&id=8091
you have to be registered with the website for viewing it i believe.
replace the xx with tt and cut out the spaces. if we arent allowed to put a link to 350z - tech . com than google "350z amp bose" itll be the 2nd link titled "[MISC] Bose Amp Schematics - ********* FORUMS
Old Jan 13, 2008 | 12:47 PM
A.E.S.S.'s Avatar
A.E.S.S.
Thanks man, I downloaded that stuff but it's complete giberish to me right now. I did read another thread where a dude had a similar problem. Anyways thanks for your help I also hope other people share their knowledge as well as this is a pretty common problem..
350Z_Al
Oct 29, 2020 07:44 PM
3vilbunny
Jul 18, 2017 05:10 PM
nanotech
Oct 2, 2015 05:02 AM
cashmoney03
Sep 27, 2015 05:24 PM
