Decided to go with FI Audio
Ok so I decided to go with FI, for my subs.
Im using the MTX 7801 (1200wRMS x 1 @ 1ohm)
So question I have from someone that has used their woofers before. What size sealed box is going to be needed for their BL series 10? It doesnt have a recommended size. If I cant go sealed with this sub I might try to get 2 SSD 10's, but feel I would be underpowering them a little bit (About 200w a piece)
BL are kinda beefy and do better ported than sealed
if you trying to do BL sealed i suggest emialing or calling Scott at FI to discuss your plan
get his input
Q or SSd are better sealed
if you trying to throw 2 subs on 1200 watts that is not enough for 2 each FI subs
you'll need double that to get full benefit form a pair of FI's
i am also fairly sure that his subs are DVC 1 or DVC 2
you would need 2 x DVC 4 ohm to see a final 1 ohm load , if your doing 2 subs off 1 amp
So do you think that getting 1 Q10 would be pretty sufficient 350Zspl? Q10 also takes 1000wRMS just like the B.
I didnt see that they made a 10Q when I was looking. On their main page it shows that they only make a 12 and 15. I guess looking around a little bit more could have helped
if you need a 10" and have 1200 watts at 1 ohm ready to go , and want to use a zenclosure
keep mounting depth less than 7" you will be fine
i would look at
FI
Q10
DUAL 1 | DUAL 2
Fs: 29.0 Hz | 26.2 Hz
Re: 0.70 Ohms/coil | 1.4 Ohms/coil
Qms: 4.80 | 5.10
Qes: .41 | .41
Qts: .38 | .38
Mms: 186g | 202g
Cms: 1.70mm/N | 1.70mm/N
Sd: 310cm^2 | 310cm^2
Vas: 22.3 l | 22.3 l
Spl: 82.9dB 1W/1m | 82.9dB 1W/1m
Bl: 10.4 N/A | 15.1 N/A
Xmax: 27mm
Rms: 1000W
Sealed box: .2-.6 cuft
Ported box: .5-1.2 cuft @ 28-33Hz
Sub OD: 11.000”
Cut ID: 9.250”
Mounting depth: 6.500”
Displacement: 0.12cuft
Product code: 01710
Price: $ 249.00
RD Classic
Mmats PRO p3 10"
RE
i would look at
FI
Q10
DUAL 1 | DUAL 2
Qms: 4.80 | 5.10
Qes: .41 | .41
Qts: .38 | .38
Mms: 186g | 202g
Xmax: 27mm
Rms: 1000W
Sub OD: 11.000”
Cut ID: 9.250”
Product code: 01710
Price: $ 249.00
RD Classic
Mmats PRO p3 10"
RE
Yea im trying to to stick with 10's so that I can go understrut. The box for my 12" L7 is massive and I have no room for anything in my hatch. I really want to go with 2 10's but im limited at 1200RMS and dont want to underpower them
they do make an fi q in 10"
your not underpowering most subs , but 2 x fi yes
Yea I wanna go FI for sure. They are based out of Las Vegas So I can save even more by going and picking up my sub from their plant. Plus any warranty issues are going to be easier to deal with
And Yea I just saw they had a Q10. On their main speaker page it says they only make a 12 and 15, so I didnt see it before.
DVC
2 ohm
feed it 1200 @ 1 ohm
i feel it will be quite enough volume for you , and still throw the 30 - 35 hertz decent
