my window is broken.
Old May 9, 2008 | 07:56 PM
1337h4x's Avatar
1337h4x
Angry my window is broken.
i tried to install a set of focals that i got today in the mail, and my passenger window will not go down/up anymore. i checked the pins on the harness between the doors, and none of them are bent. what did i do????
Old May 9, 2008 | 07:57 PM
lukep90's Avatar
lukep90
i have the EXACT same problem!
subscribed for the answer...
Old May 12, 2008 | 07:54 AM
DVFlyer's Avatar
DVFlyer
Speed of White
You have to reset the window circuit..... Hopefully someone will chime in with the answer because I can't remember how.
I seem to remember it might even start to work by itself after a few key turns.
Old May 12, 2008 | 08:03 AM
doug's Avatar
doug
i had the same problem.. the wires i ran through the driver side door didn't allow the pins to make full contact..
my suggestion is to pull the wire out.. then snap the harness back together and see if the windows work
Old Jul 19, 2008 | 01:16 AM
EFLoW's Avatar
EFLoW
Did you ever get the window working? If so how did you fix it? I just finished an install and I have the same exact problem. My passenger side window and mirror doesn't work and my drivers side lock doesn't work.
I had to cut through the harness between the door too and I was extra careful not to cut into any pins being used.
Can anyone help?
Old Jul 19, 2008 | 07:06 AM
doug's Avatar
doug
Can anyone help?
did you do what my post above you said?
Siqcology
Sep 18, 2019 01:45 PM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
Dymsi
Sep 29, 2015 11:32 AM
AP350z223
Sep 8, 2015 04:38 PM
