Trim for Xenarc LCD, where to find?
Old Aug 7, 2003 | 07:38 AM
etx's Avatar
etx
Default Trim for Xenarc LCD, where to find?
Hey guys, now that Ive got the xenarc in and working great my only problem is at night when its on I get the light bleeding in from around the screen. I feel I mouted it very straight and centered but some kind of molding to go around the edge would block that light and make it look nice. So has anyone done this? I searched and found nothing. If thier was some kind of self adhesive black rubber corner molding i could use to outline the LCD it would be perfect!
Old Aug 7, 2003 | 02:30 PM
chromesilverz's Avatar
chromesilverz
You shouldn't need any trim...the only light that should come out is from the front (screen).
Old Aug 8, 2003 | 06:48 AM
etx's Avatar
etx
check out "Da Gimp"s post with the pics of his screen. Look on the left hand side of the screen you can see a line of light on the side. Mine is on the right so in the drives seat i bugs me. I was thinking about using some black RTV to form a border but then it will not be serviceable... Anyone have any ideas? thanks!
Old Aug 8, 2003 | 09:03 AM
ares's Avatar
ares
Veteran
black clay? push it into the corners to seal them up? get non drying clay, and it should just sorta chill there....
Old Aug 8, 2003 | 03:31 PM
etx's Avatar
etx
umm, no thanks man. If thier is no other solution ill just go with the silicone rtv. thanks
Old Aug 8, 2003 | 08:23 PM
ares's Avatar
ares
Veteran
yeah not ideal, just thinkin of non permanent things that could just fill the gap. same way as the silicone, but not as permanent...
Uriyo_
Sep 8, 2021 08:46 AM
burglapfd
Dec 6, 2020 01:04 PM
Tochigi_236
Sep 27, 2015 03:40 PM
SharX59
Sep 27, 2015 09:23 AM
