sub and amp problems
Old Oct 5, 2008 | 05:21 AM
shinz's Avatar
shinz
Default sub and amp problems
I've recently had a sub and amp installed, but the sound seems off. The sub is a single Image Dynamics ID 10", amp is an alpine mrp-m350, and sub is enclosed in a zenclosure box. The speakers and headunit are still the stock Bose.
Anyway, I just had the sub and amp installed, and the sub seems to really overpower the speakers, making the overall sound quality bad. I wouldn't say the bass is too loud, but things kind of sound out of sync in some way. I'm not really sure how to set up the amp settings so I set the gain, bass, etc to the middle mark, which I'm sure isn't optimal. The headunit settings are all set to default 0. I will be purchasing front components, as well as a kenwood ddx-7015 HU, which I'm hoping will balance out the system and sound.
Another problem I'm having, which I'm not sure is normal, but sometimes the sub creates a rumbling tone for a second or two, almost like a hum, which sounds really out of place in the songs. It seems to happen more often if I put the headunit volume lower, at around 8 or so.
The main problem I noticed is that the bass gets a lot louder when the car is stopped. Once I stop at red lights or stops signs, the bass gets moderately louder, but returns to normal when I start driving.
Anyone have any advice to remedy these problems? Sorry if the descriptions are bad, not really sure how else to describe them. Thanks.
Old Oct 5, 2008 | 06:54 AM
RandyK1's Avatar
RandyK1
You could try reversing polarity on the sub (swap the + and - wires around on the sub, this wont hurt your sub) this makes your sub cone suck in whall your other speakers cones are out (its a sound pressure thing) or turning the amp gain down abit, or both.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
