My Car is Messed up
Old Sep 20, 2003 | 08:00 PM
supra crazy's Avatar
supra crazy
Angry My Car is Messed up
ok today i was trying to remover the door panel to insatll my new kappas that i got yesterday but the srews in the door panel where the window switch is just keep spinning does any one know y id does that and how can i get the screws out
Please help me!!
Old Sep 21, 2003 | 06:51 AM
supra crazy
please!!
Old Sep 21, 2003 | 01:03 PM
jor8888's Avatar
jor8888
Keeps spinning?
1. Get something to pull it out?
2. Get something to pull it out as hard as u can and turn the screw at the sametime.
3. Get a drill and drill out the screw.
Old Sep 21, 2003 | 04:40 PM
supra crazy
but i need the srew to srew ut back in
Old Sep 21, 2003 | 04:46 PM
Stone Z's Avatar
Stone Z
You'll have to buy new screws with the same thread size.
When I was putting my passanger door back together, I stripped both bolts in the verticle door handle (the piece with the brushed aluminum and three dots). I removed the bolts, took them to Ace Hardware, and got two new bolts. Good as new.
Don't worry....you'll get them back in and it will be just fine.
Old Sep 22, 2003 | 08:58 AM
peptidbond's Avatar
peptidbond
Whoa...don't need to do any of this. I had the same issues. The screws at the arm rest go into nylon sockets. The nylon sockets will rotate as you turn the screw. My solution: pull back on the arm rest as you turn the screws. This apparently creates enough pressure to keep the nylon sockets from turning with the bolt. If it is squeeking, it is slipping. You will get the hang of it.
etkms
Jun 19, 2022 06:30 PM
rizzla
Drag
Sep 17, 2015 08:44 AM
