alarm "scanner" -- help with wiring
Old May 12, 2009 | 06:55 PM
dsmZ's Avatar
dsmZ
Default alarm "scanner" -- help with wiring
I recently installed one of the led "scanners" for your alarm (maybe 5 or 6 led's which pulse back and forth, different patterns, etc...) For the install you need a constant 12v, ground, and accessory 12v which will turn the light off once the key is inserted/car is started. I hooked the constant to the yellow wire from my radio, a common metal chassis ground, but for the accessory I hooked it up the the red radio wire. It would turn off once the car is started, but once the key was removed, it would never come back on.
Question is: is there a -better- accessory wire I should be using? if so where would it be located and what color. thanx!!
Old May 13, 2009 | 03:05 PM
dsmZ's Avatar
dsmZ
177 views and no one can SUGGEST a good accessory wire which MAY work in this application? come on people!
350Z_Al
Oct 29, 2020 07:44 PM
bcoffee20
Nov 19, 2015 06:39 PM
nanotech
Oct 2, 2015 05:02 AM
cashmoney03
Sep 27, 2015 05:24 PM
Beater350z
Sep 9, 2015 03:36 PM
