Viper 5901 - won't learn tach
Old Sep 15, 2009 | 09:13 AM
djamps's Avatar
djamps
Default Viper 5901 - won't learn tach
Anyone successfully learned the tach with a Viper 5901 or equivilant? Which wire did you use?
I'm using coil #1 signal off the ECU and the darned thing won't learn it.
I also tried flipping the jumper on the back of the alarm brain according to the docs (required for some vehicles) but it still won't learn it.
So I'm stuck using virtual tach (voltage sense) which works OK for regular old remote start but doesn't allow valet take over or turbo timer operation.
Thanks in advance.
Old Sep 15, 2009 | 12:46 PM
KPierson's Avatar
KPierson
I would use a fuel injector, not a coil. It's duty cycle is much higher making it an easier signal to read.
NttnbutaZthang's Avatar
NttnbutaZthang
you should go under the hood and use one right from a coil...i used one from there and learned no problem
Old Sep 17, 2009 | 05:26 AM
djamps's Avatar
djamps
I'll try an injector wire instead. When I finally get everything working right I'll post a write up.
Cheers
Old Sep 17, 2009 | 06:27 AM
KPierson's Avatar
KPierson
You can grab it right at the ECU under the passenger dash - no need to go under the hood.
sherm
Apr 11, 2020 05:21 PM
Depravity
Oct 1, 2015 04:49 PM
Tochigi_236
Sep 27, 2015 03:40 PM
