color of speaker wire?
Old Oct 11, 2003 | 09:25 AM
Vash's Avatar
Vash
Question color of speaker wire?
After I done search of "Basslink" and "speaker wire" I have no luck to located and identified those speaker wires.
I have couple question regarding wiring to basslink form factory base HU.
Is anyone can tell where to tap get all the speakers wires?( I mean where is the rear speakers wire in the fornt) and how do you know identified of those wires (color) please. Thanks in advance
Vash
BTW, I looking to buy left over of dynamat or similar. https://my350z.com/forum/showthread....threadid=45722
Old Oct 13, 2003 | 09:08 PM
bastard's Avatar
bastard
Why don't you just patch into the rear speakers at the rear speakers?
Old Oct 15, 2003 | 06:16 PM
grutter's Avatar
grutter
Neither the base HU nor the BOSE have sub outputs from the HU. The base unit doesn't have a sub at all, and the input to the sub amp on the BOSE system comes from the BOSE speaker amp.
I haven't ever hooked up a basslink, but I believe it has an option to use either 2 channel or 4 channel speaker level inputs. IMHO, the easiest way to get that would be with a cablelink adapter so you can just plug into the existing harness. If you are trying to splice into the wiring, the color codes appear to change, depending on if the car is MT, without NAV, VDC and power seats.
The pin-out at the HU stays the same, however.
LF - Pin 1 Connector M40 (10 pin connector)
LF + Pin 2
RF - Pin 3
RF + Pin 4
LR - Pin 13 Connector M41 (6 pin connector)
LR + Pin 14
RR - Pin 15
RR + Pin 16
The pins on the connectors are
M40:
10 8 xxxxx 4 2
9 7 6 5 3 1
M41:
16 xxxxx 12
15 14 13 11
Old Oct 15, 2003 | 07:19 PM
Vash's Avatar
Vash
Thanks for your info. I got this Nissan wiring diagrams online. Just ignore those colors. They are incorrect, but all the pins position is good to go.
I spliced all the wire at the HU. Then run all the wire and power cable via the center console to the stock sub location without any problem. ( thanks for Zaph32's post, I pre-cut that dame metal tab in the stock sub area before the my Bass link arrived)
BTW. Those rear speaker wire's color are not 1 piece. They are different colors at the rear speakers and at the HU (I don't know the front, since I haven't take the door panel off.)
sales@czp
Sep 23, 2019 03:30 PM
kyin
Oct 15, 2015 05:54 AM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
