wiring my component speakers and amp
Old Nov 5, 2009 | 06:36 PM
dsmZ's Avatar
dsmZ
Default wiring my component speakers and amp
hey guys. im going to be changing up my audio setup a bit and thought i had everything understood pretty well, but a friend of mine gave me some advice which Id like to share with you guys to see who's correct:
i have a kenwood ddx512, infinity 6020cs components, and a jl audio 10w3v3-2 (2 ohm)
im going to be buying 2 amps, one for the sub and one for the components. now MY understanding was that i would connect an RCA cable from my HU to the input side of my sub's amp, then connect another rca from my sub's amp's output side to the RCA input of the component speaker's amp---
my friend said that doing this would cause signal distortion and that i should wire up my front components to the "front" output on the HU and the sub to the "rear" output on the HU... basically making the two completely independent of each other.
which would be the better (or the correct) setup? this is a vital step because some amps have rca outputs and some dont, and i dont want to buy something i cant use. any help would be appreciated!!
Old Nov 5, 2009 | 08:54 PM
hellsoldiers08's Avatar
hellsoldiers08
Honestly i would go for the 10w6 if you dont mind loosing some more space, def. worth it in my opinion.
Old Nov 6, 2009 | 06:27 AM
StreetOC192's Avatar
StreetOC192
I would suggest running 4 channels of RCA's. 1 stereo pair from the 'front' outs of the headunit to the amp powering the components. Then 1 stereo pair from the 'sub' outs from the headunit to the amp powering the subwoofer.
Could you run 1 stereo pair of RCA's to a sub amp, then from the sub amp's 'preamp output' to the amp for the components? Yes, but then you lose the ability to use the built-in crossover, equalizer, and fader in the headunit.
Old Nov 6, 2009 | 07:48 AM
dsmZ's Avatar
dsmZ
ah, this is true... so basically i can go with a setup of amps with no rca outputs, correct? i completely forgot about losing the ability to use those functions! thanx
Old Nov 6, 2009 | 08:35 AM
StreetOC192
Correct. Don't buy an amp just because it has a preamp output (or passthrough as some call it).
Old Nov 6, 2009 | 03:21 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
The best part about running cables straight from your headend to the subwoofer and components separately is that normally the headend has some signal processing/controls for the subwoofer. Mine has a built-in crossover adjustment and bass level (gain) control. Adjustments using the headend GUI is pretty easy.
Old Nov 6, 2009 | 06:19 PM
dsmZ's Avatar
dsmZ
thanx guys.... doing a new audio setup as well as some exterior work... look out for pics in the upcoming weeks
350Z_Al
Oct 29, 2020 07:44 PM
3vilbunny
Jul 18, 2017 05:10 PM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
