Rear DVD/SatNav Compartment
Old Oct 20, 2003 | 02:36 AM
uklooney's Avatar
uklooney
Default Rear DVD/SatNav Compartment
Does anyone know if a unit like so..
will fit in here...
It's dimensions are 7"(W) x 2"(H) x 10"(D)
or 177.80mm x 50.80mm x 254.00mm
It's slightly larger than DIN, but it's the depth that I am more concerned about....
Old Oct 20, 2003 | 01:32 PM
USMC-Z's Avatar
USMC-Z
Z Veteran
Im not sure about if it will fit, but where did you find that at?
Old Oct 20, 2003 | 04:00 PM
Natal's Avatar
Natal
From the URL on the image, it looks like he found a mini-ITX Model C134 from Travla.com .
The website indicates Dimension(WxHxD): 7" x 2" x 10" or 177.80mm x 50.80mm x 254.00mm, so maybe someone else can figure out if it fits in that letterbox.
Additional specs and info can also be found at this Casetronic link.
Old Oct 20, 2003 | 04:55 PM
jesseenglish's Avatar
jesseenglish
Here's one that's even smaller
http://www.cappuccinopc.com/1baypc.asp
Attached Thumbnails Rear DVD/SatNav Compartment-img_1bay.jpg
Old Oct 20, 2003 | 06:05 PM
sybersnake's Avatar
sybersnake
Make your own.. some plexi glass and whatnot. Drill holes if you cannot fit some parts.. and just attach them to the top of the storage compartments.. or in the back area.
Old Oct 21, 2003 | 08:18 AM
cliffart's Avatar
cliffart
The C-134 will fit in the compartment since it's a 1 DIN size. You can even purchase the CD changer mounting kit from Nissan to hold it it place. The only problem is it's a little too long for the pocket and will stick out a bit. I bought it a few weeks ago and am going to put it in the subwoofer compartment......hope the vibrations won't effect it. Check out this site:
http://www.swooby.com/z/navpc/
He has done what I think you want to do.
