KICKER ZX Series ZX750.1 Amplifier
Old Mar 16, 2010 | 11:12 PM
tw8715's Avatar
tw8715
Default KICKER ZX Series ZX750.1 Amplifier
so i got a KICKER ZX Series ZX750.1 Amplifier
and i got the 350z under the strut car box.
that hold TWO 10" woofers.
im planning on getting the JL w3v3 subs.
i heard it depends on which amp you have that you decide if you want 2ohm or 4 ohm subs.
which ohm subs do i need?
Old Mar 16, 2010 | 11:14 PM
tw8715's Avatar
tw8715
here is a link to some info on my amp
http://review.zdnet.com/product/car-...ifier/31971291
it says: Amplifier Output Details
375 Watt - 4 Ohm - 1 channel(s), 750 Watt - 2 Ohm - 1 channel(s)
no idea what this is lol
Old Mar 17, 2010 | 02:03 AM
duro78's Avatar
duro78
Why is everyone on this site stuck on kicker and jl but anyway if I were you i would find a class d amp that is 1 0hm stable so you can get the max out of your amp then buy 4 ohm dvc and wire them to 1 ohm. Class d can make that power more effienctly. You kind of have to think ahead what ohm you want to run then that determines what amp and sub configuration to run
Old Mar 17, 2010 | 03:12 AM
tw8715's Avatar
tw8715
i already have the amp sooo~
not sure of all the terms here. simple answer would be awsome? lol
and if nice enough.. explanation too lol
and i think my amp is class D. whatever that is
Old Mar 17, 2010 | 03:16 AM
nismo542's Avatar
nismo542
nice amp, good quality.
with that amp you need to run the subs at 2 ohms. that is the resistance of the voice coils in the sub.
you can achieve this in a few ways. get 2 single 4 ohm voice coil subs and wire them in parallel. or you can get 2 dual 2ohm voice coil subs, wire the subs in a series parallel combination.
what you need to make sure of is that the RMS wattage the subs can handle is close to the RMS wattage the amp will supply. RMS stands for Root Mean Squared and is the continous wattage that can be deliverd. dont go by the "max" ratings of subs and amps.
the jl 3v3-4 10" can handle 500 RMS watts. you amp can supply 750 RMS. so you would be fine running 2 of those subs on that amp. the subs could handle 250 more watts then the amp can supplt but that is fine.
you wouldnt want to put more rms watts to a sub then it can handle, this will shorten the life of the sub. so you wouldnt want to run the w0 or the w1.
just because an amp might say it is 1 ohm stable doesnt mean you should run it at 1 ohm. what you gain in power you trade in sound quality. plus it would be like running your engine at red line all the time. people are stuck on jl and kicker because they make quality equipment that is affordable and available. there are better brands but there are many that are worse.
Old Mar 17, 2010 | 06:46 AM
duro78's Avatar
duro78
^^^Huh? thats absolutely not true if an amp is 1 ohm stable doesnt mean your running it at a detrimental level its actually running more efficiently. You can run an amp all day long at 1 ohm and it not even get warm.That is in no way compared to running an engine at redline. How are you losing sound quality for running at 1 ohm if thats the case your running a very low quality amp. How do equate kicker with quality yes some of there stuff is ok but it is by no means what it used to be nothing they offer is for sq its al spl and jl and affordable do not go together. For the same price of there subs and amps you can get equipment that blows it out of the water. People are stuck on jl and kicker because its mainstream and they just dont know any better. What audio show have you ever been to where kicker or jl is being used ppl that know any better dont run it. Digital designs, Dc audio, FI,Rd logics, incriminator audio, audioque etc etc find me anything in kicker or jl's line that can come close to touching anything from 1 of these companies
To the original op i suggest going on caraudio.com and doing a little research to learn more about car audio or else its either gonna result in damaged equipment or not using it to its full capability.
Old Mar 17, 2010 | 08:05 AM
nismo542's Avatar
nismo542
just trying to help him get a setup with an amp he already has. i wasnt suggesting product to buy. it doesnt look like he is going for a competition sq setup. he is just trying to match some subs he wants to the amp he has.
Old Mar 17, 2010 | 05:01 PM
tw8715's Avatar
tw8715
No easy answer eh?
2 or 4 ohm?? Lol
must I do a poll haha
Old Mar 17, 2010 | 08:59 PM
JE'S350z's Avatar
JE'S350z
You don't need a poll just learn to read
So your options are buy 2 subs that are single voice coil 4 ohm subs or get 2 subs that are dual voice coil 2 ohm subs. It really doesn't matter if you get 2 ohm or 4 ohm subs you just have to wire them the correct way for whichever ones you buy. The instructions that come with the subs will tell u how to wire them or search on here I have seen wiring diagrams for a few different setups in the audio section
Old Mar 18, 2010 | 05:33 AM
nismo542's Avatar
nismo542
here are your 2 options. both will give you a 2 ohm load at the amp. the top one is with 2 single voice coil subs that are 4 ohm each coil. the bottom one is with 2 dual voice coil subs each coil is 2 ohms. hope this clears up any confusion.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Twenty4
Jan 17, 2016 01:20 PM
