Kenwood DNX 5240BT
Old May 28, 2010 | 08:13 AM
Mastoras's Avatar
Mastoras
Default Kenwood DNX 5240BT
Hello. Recently i purchased a double Din Kenwood DNX 5240BT. Anyone knows what adapters i need to run it smoothly ? I also want to keep my steering wheel controls active. My car is a 350Z 06+ Bose. I want to upgrate the Headunit only and keep the rest sound system stock.. Thanx in advance
Old May 28, 2010 | 09:24 AM
Litesung's Avatar
Litesung
Ask ... an electrical engineer
Old May 28, 2010 | 10:24 AM
Mastoras's Avatar
Mastoras
I did it and i found out most of them dont know or want to charge the triple from what those adaptors cost. Thats why i am asking here.. to buy those parts myself
Old May 28, 2010 | 12:15 PM
arsey51's Avatar
arsey51
Why aren't you upgrading your speakers as well? You'll have a nice HU with lousy OEM speakers. Not a good combo - but its your car and your ears..........
Old May 28, 2010 | 12:26 PM
WESTINZ's Avatar
WESTINZ
Masrotas, I am considering doing the same thing. I am not looking for an audio upgrade the Bose is just fine for me but I would like to upgrade the HU for bluetooth and MP3 capabilities. I think there is a potential problem with using the Bose speakers because they run different ohms if I have understood correctly. Not sure what problem this causes, blown speakers, distortion etc. They do sell an aftermarket line converter for use when changing the HU and keeping stock Bose speakers and amp but I'm not sure how they work. Hopefully someone with knowledge in this area will reply to our post.
Old May 28, 2010 | 12:34 PM
arsey51's Avatar
arsey51
Yeah, I beleive Westinz is correct in that the Bose speakers are 2 ohm and your new head unit is 4 ohm. I wasnt' aware you ware running the Bose system. Just my 2 cents, but I think Bose is overated and you can do much better installing upgraded speakers with you new HU. I have a similar Kenwood double din HU with Kenwood amp and FOCAL speakers, componets in the doors and full range in the rear, no sub. Upgrade with new speakers.
Old May 28, 2010 | 03:07 PM
Mastoras's Avatar
Mastoras
After some research i found out that you need the adaptor PAC ROEM-NIS2. Without this the amp for Bose System will not work and our speakers will not perform good. Westinz and arsey you are both right. Well i agree about Bose performance,its probably overated. But for now i want to keep the budget low. I swap the HU for MP3,Bluetooth and some other capabilities like Westinz. Dunno a lot about ohms :P. If i am not happy i ll upgrade speakers and amp.Also i find PAC SWI-JACK adapter to keep my steering wheel controls active after the swap. Just need some expert's opinion to verify it.. thanx for your concern guys
bcoffee20
Nov 19, 2015 06:39 PM
dcains
Nov 11, 2015 11:36 PM
Wicked4u2c
Sep 3, 2003 07:30 PM
jhagan
Audio Builds
Aug 1, 2003 04:49 AM
