~~>{SQBassHead's Audio Build}<~~
Old Jun 15, 2011 | 06:55 PM
  #121
SparkleCityHop's Avatar
SparkleCityHop
Living in 350Z
Originally Posted by 350zspl
RF T20001 BD i used in 2006
RF T40001 BD i used in 2007-2008
i was buying them at dealer cost at that time and that is why I used them
Similar situation here. Friend runs an audio shop and he mainly sells RF, Kicker & Orion - so I'm going with RF speakers and amps so that I can rep his business at some local shows & he's giving me the equipment at cost, letting me use his air conditioned shop to do some of my work, and helping me out in general.
I'm planning on two of the 12" T1/T2 subs. I'm also considering the possibility of two 8" midbass drivers as well, but not sure yet. I want to hear the performance of the 12's by themselves and see if they will suit all of my varied musical tastes. Considering the 6.5" T3 components for the kickpanel and a pillar for normal listening. I'm planning to have less expensive 3.5" left and right behind each headrest on a separate volume control specifically for top down, high speed listening (think headphones).
I drive 90% of the time with the top down, so that really factors into my plans. It sounds like you guys have some real experience, so any advice that you can give me, I'm all ears.
Old Jun 16, 2011 | 12:44 AM
  #122
My LT Won's Avatar
My LT Won
yes crunch gp 3000d -pro
3000 x 1 @ 12 V @ 1 ohm
4000 x 1 @ 14 V @ 1 ohm
runs .5 ohm with the correct electrical
strappable
and runs on 16 volt set up
these amps are probably the single best 3000 watt amp ever made IMO
they are discontinued
i have 2 mint units
and i am buying a 3rd
just really like all aspects of it
as well as the appearance
sundown makes a top notch product , i still am a dealer for sundown
i really like your install. what kind of volts do you see at fult tilt? also where did you get your dual awg terminals?
Old Jun 16, 2011 | 04:32 AM
  #123
350zspl's Avatar
350zspl
Originally Posted by SQBassHead
Sparkle city- idk about the glenlivet 25yr... But I deff need to try the other two.... Even if I prefer tequila... I still have my moods lol
Travis- I'm not going to in any way duplicate your front stage..... But dude! I have some doors with pods that I was going TL put my components that I had in the rear in the funny thing is that my kicks are suede and the pods are leather we almost have the same shii lol
Trip out bro... Oh well
i should have either had Nazar fab my pods in suede , or had Bing fab my kics in leather , instead of having them mis-matched
i foocked up
but i got them done at different times , yet that is not an excuse
yes we do have the same tastes so it does not surprise me
good stuff
side note the DD W6.5 mid bass drivers are really sick and handle GOBS of power without breaking a sweat, and the DD-A Germs 5.25 mid range drivers are very nice , digital design's line is top notch
Old Jun 16, 2011 | 04:43 AM
  #124
350zspl's Avatar
350zspl
full tilt is at 14 volts , when the lows get to 35 hertz and less the voltage drops to 13.5 volts
with the amount of 0 awg runs i have , plus the big 3, plus the 200 amp alt, plus the stinger sp series batteries, it does not spike up and down it rests steady , with the stereo playing at mid volume the voltage is 15 volts , and in the winter time here in Florida temps get to 60 degrees in the day time the voltage is even higher than 15
if you go to caraudioclassifieds.org you can find toolmaker , and toolmaker fabs anything you need connector wise out of aluminum or copper, his work is sick
Old Jun 16, 2011 | 05:18 AM
  #125
350zspl's Avatar
350zspl
i did not mean to discourage you in your thread, but my experience with verts has been , like i mentioned with the top down on the highway the faster you go the more sound you lose, meaning as someone suggested in your thread just turn it louder, well yes turn it louder and you beginning to introduce distortion
does not mean that you can't have a good system and have fun
i just wanted to make you aware of that before you start cutting up the car, and spending tons of money of equipment, and tons of time doing the work
if your car is automatic and has no clutch you can fit 8" mid bass drivers in the kick panels , just lose the foot rest, and i would have done that myself , but my car is manual
On RF as far as Components go i am gonna say get T5 series in 6.5" , the markup off MSRP is 50%
if not than get the T3 in 6.5"
get a head unit that is at least 4-6 volts out so you don't have to gain your amps as high
T2 subs are nice i used them in 2004-2006 i will throw some pics i would use at least 1.75 to 2 net cubes per 12" T2 sub, after sub and port displacement , if you can't devote that space then use T2 10", tune at 35 hertz for music
I don't like the idea of 3.5" speakers behind your head at all , but it is just my opinion and it is subjective so do what you like, i don't like sound stage coming to my ears from behind
make sure you do the big 3, make sure you use a ton of sound deadner, make sure you use 0 awg power & ground , if your using the factory alt fine i would upgrade your underhood battery
my 1996 impala with 2 each T2 15" @ 35 hertz off a T20001 BD , the drivers are sharing 2900 watts here at 1 ohm
my 1995 caddy deville
lastly on the RF amps try to see a 1 ohm final load , and the T2 drivers i think are rated at 1000 rms , i fed mine as much as double , but i would suggest using at least 1500 watts per sub, because in your set up with voltage drops and box rise you won't see 1500 watts and it will be closer to 1000
better to have more power on tap than less
Old Jun 16, 2011 | 06:06 AM
  #126
SQBassHead's Avatar
SQBassHead
i foocked up
good stuff
Same here bro.... I bought the kics and pods at diff. Times
kics by bing and the pods i bought used from a member local... Its like it was Kent to be ... Lol ... He put them up for sale right after I pulled out all the metal and plastic ... And for $100 I can't complain lol ... He had bought them from nazar....
Old Jun 16, 2011 | 12:06 PM
  #127
My LT Won's Avatar
My LT Won
thanks for all the helpful info.
Old Jun 16, 2011 | 12:32 PM
  #128
Jackson0927's Avatar
Jackson0927
Ya I want me some of them, saw these when they first released them. more than I will spend on speakers tho......
Old Jun 16, 2011 | 12:42 PM
  #129
SQBassHead's Avatar
SQBassHead
Jackson.... Check out the HAT imagines of you don't want to spend much
There even going to release a lower priced true coaxial model I've heard nothing but great things about this imagines... That there better then ALOT of the more expensive components ....
Just a thought
  #130
350zspl's Avatar
350zspl
Jackosn 0927 i would buy SEAS for that kind of money
BUT the sparkle city hop narrowed down to 3 manufactures
orion
kicker
RF
so RF > Orion & kicker
Old Jun 16, 2011 | 01:09 PM
  #131
SQBassHead's Avatar
SQBassHead
Seas are straight up badass!!! Lol
For that type of money I would deff look into seas.... But t5's 50% mark up!!!!! Omg!!! Dang that would be a pretty sweet deal to get it at cost lol
Still.... Jackson if you don't want to spend 500 for speakers .... I would deff look into the imagines.... Many ppl swear by them .... I cant wait to see if hat lives up to the hype
Old Jun 17, 2011 | 08:13 AM
  #132
Jackson0927
ya, you guys have got me wanting to re-do every part of my audio system.
do it right this time, but i gotta spend cheddar on the other parts of my car first,
think im going to start planning it out, and tear into it this winter or fall.
Old Jun 17, 2011 | 09:36 PM
  #133
SQBassHead's Avatar
SQBassHead
All righ so I got a chance to start laying the SecondSkin
Before:
After:
Still not done.... I'm going to try and finish it up tomorrow
What sux is that my passenger seat motor gave out so I can't move the seat foward and was to lazy to pull the seats out so I was crunched on the back awkward positioning for sure! Lol
Old Jun 18, 2011 | 05:10 AM
  #134
350zspl's Avatar
350zspl
takes only 5 minutes to pull the seat
don't let the quality of the work suffer due to being cramped with no space
pull the seat
hey are you wiping down the with alcohol before you roll that deadner on
Old Jun 18, 2011 | 08:37 AM
  #135
SQBassHead's Avatar
SQBassHead
Yeah I cleaned the whole back area before I started ... Hence the towel covering the subwoofer...... Man I was scrubbing and peeping for atleast 1hr ... Lol
But since the seat doesn't move foward or back .... Can I still take the seat out .... Meaning will I be able to reach the bolts?
Awkward positioning but it was nothing that Two fluffy pillows fixed lol
The rest is all flat so it's not hard at all.... Hardest part was the wheel welds I'll finish it up today and post pics .... Man I forgot how tidings this shii!!! Was ... Lol I was FKN sweating !! Lol
Old Jun 18, 2011 | 08:41 AM
  #136
SQBassHead's Avatar
SQBassHead
Travis the before pics were pics taken right after the work was done.... Lol now I see why you asked if I cleaned it.... It was dirty and dusty ... Lol
But yeah bro .... This pics are old .... There the same pics I used before lol
Thanks for looking out bro...
Old Jun 18, 2011 | 10:46 AM
  #137
350zspl's Avatar
350zspl
i guess i missed , but i see it now , you mentioning the seat is stuck & power
if you can not access the front & rear seat bolts , than it can't come out
my bad
you are gonna need to get that seat resolved
no biggie
keep moving foward
Old Jun 18, 2011 | 11:24 AM
  #138
SQBassHead's Avatar
SQBassHead
Lol... It's cool bro....
For sure I can't access the bolts on the rear of the seat .... But I'll figure something out...... I'll post some new pics after.... But man just on the one side I did ... You can tell a BIG diff in reduced road noise gf even noticed it! So I know it actually worked and it wasn't just in my head
Old Jun 18, 2011 | 02:07 PM
  #139
350zspl's Avatar
350zspl
not only does it reduce road noise
it rejects heat
before you started if you would have pounded on that metal it would have felt like a beer can , after you put down the deander solid like a tree trunk
Old Jun 18, 2011 | 04:00 PM
  #140
SparkleCityHop
Living in 350Z
Pick up a set of metric ratcheting wrenches that have swivel heads. One of the best tool investments that I've made. With the swivel head, you can get it into tight spots like that, and since they have the ratchet built in, it makes the job soooooo much easier.
