Kicker compVT 6.5 question.
Old Jun 11, 2011 | 01:36 PM
tim quibodeaux's Avatar
tim quibodeaux
Default Kicker compVT 6.5 question.
Will they fit in rear speaker location? Thanks
Old Jun 11, 2011 | 03:06 PM
gvulakh's Avatar
gvulakh
Most likely yes.
Go to crutchfield.com and outfit your car and see if these have a green light for fitment.
Old Jun 11, 2011 | 03:26 PM
binder's Avatar
binder
I think they are too deep on the doors and you need custom spacers.
what are you going to do for mids and highs? You do know that you can't play full pass music through these subwoofers without damaging them (and it sounding like crap) don't you?
Old Jun 16, 2011 | 02:41 PM
bigbgballz's Avatar
bigbgballz
They will fit as far as depth goes. I have those but never got to installing them. My only concern is if there is enough room between the rear speaker panel and the mounting rim of the woofer and the movement of the cone hitting it, may be some of the experts here can chime in here, please update if you end up installing them.
Old Jun 20, 2011 | 09:42 AM
binder's Avatar
binder
really? I had to use a 3/4" spacer just to fit a standard depth 6.5 in mine otherwise the window hit it when rolled down. The specs on those compVR's are quite a bit deeper than the infinity kappa's i installed.
Old Jun 28, 2011 | 08:02 PM
bigbgballz's Avatar
bigbgballz
It says rear speaker location, I believe he means the rear speakers not the ones in the doors. They will definitively not fit in the doors without spacers.
Ace2347
Sep 22, 2015 03:12 AM
_koubie_
Sep 20, 2015 06:34 PM
