CD Changer and EQ Addition
Old Jan 24, 2004 | 06:20 AM
zachcrosen's Avatar
zachcrosen
Default CD Changer and EQ Addition
I am continually having problems with my factory Bose stereo skipping when the weather is cold. It is so bad that I can't even listen to CD's when it is cold outside. Have anyone else had this annoying problem. Anyway, prior to buying my 2004 350z, I had spent about $475 on a Pioneer CD player with a flip down face and the OEL display, the opne with the screen saver like display. I really want to put that back in my car but I dont want to lose the changer. I have seen posts about adding a cd changer to one of the rectangular boxes behind the seats. Does anyone have any instructions on how to so this install and what is needed so that it looks neat and where it can be bought. Also, I am considering adding a Pioneer EQ in the same opening as the CD player I want to add. I believe that 2 DIN size receivers will fit in the factory stereo opening. Can someone please confirm. And if they will both fit, what hardware is needed and where can it be bought? Thanks for any help.
Old Jan 25, 2004 | 09:59 AM
kbirdsong's Avatar
kbirdsong
I had mine done that way. And good installer will have no problem doing this for you.
Old Jan 25, 2004 | 10:22 AM
zand02max's Avatar
zand02max
Here's mine 6 disc Pioneer
Old Jan 26, 2004 | 03:19 PM
zachcrosen's Avatar
zachcrosen
Thanks for the help. Do either of you know the dimensions of the changer that is installed in your car. Also, what equipment or hardware is needed for this install. I went and talked to a local installer and they had never done any work on a 350z before. SO I am just a little curious about any necessary mounting stuff and trim work that was needed to complate the install.
Old Jan 26, 2004 | 06:37 PM
kbirdsong's Avatar
kbirdsong
The dimensions on mine can be found on www.alpine.com it's a model CHAS634. I would however find an installer who has done several Z's at least. Nearly the entire interier has to come out to install speakers, changer and headunit. The amp is in the hatch so a bunch of that must come out too. I wouldn't let someone learn on your Z.
Old Jan 26, 2004 | 06:39 PM
kbirdsong's Avatar
kbirdsong
BTW on mine the factory door still goes over it, if you like the stealth look.
ablaine
Nov 29, 2016 10:13 AM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
nanotech
Oct 2, 2015 05:02 AM
