MUST SEE: Mini in Car PC
Old Jan 31, 2004 | 04:12 AM
aalzuhair's Avatar
aalzuhair
Thumbs up MUST SEE: Mini in Car PC
Hi all,
You guys must see, I think it can fit in the rear top box (mailbox looking thing).
Link: ePC 3
Specifications:
Processor
¨Intel P4 Processor
¨Supports processor 478-Pin
¨CPU system bus at 400/533 MHz
System Chipset
¨SIS 651
Memory
¨0KB on-board
¨Two slots support 200-pin DDR266/333 RAM
Video
¨Max. 64M Video RAM (Share memory)
¨AGP 2.0 compliant (4X)
¨Support for up to 1600 by 1200-pixel resolution at 24bits per pixel (16.7millions of colors)
¨15pin VGA connector
Data and Media Storage
¨One 2.5 inch 12.5mm high Hard Disk Bay
¨One ATAPI-IDE interface for high speed slim type CD-ROM or DVD-ROM, DVD-CDRW COMBO Drive
Speakers and Audio
¨Built-in Sound Chip
¨Built-in Speaker
¨One Mic-in port (Front)
¨One ear Phone (Front)
¨One line-out port
¨One line-In port
¨One SPDIF Port
Communications
¨Built-in IrDA
¨Built-in one 10/100/1000 Mbps Ethernet And one 10/100
Ethernet
¨Built-in 56K V.90 Modem card
¨One RJ-11 connector
Peripheral connections
¨TV-Port (support 1024x768, S & AV)
¨Two mini type FireWire (1394) ports (400 Mbps)
¨Four USB 2.0 ports
¨One 9 pin serial port ( RS-232)
¨One 25 pin Parallel port ( EPP /ECP)
¨One Type II PCMCIA slot
Keyboard and Mouse
¨Supports any standard PS2/ USB mouse
¨One 6 pin PS/2 mouse port
¨One 6 pin Keyboard port
Electrical requirements
¨Line voltage 110V(90V to 130V AC) or 230V AC(180V to 260V AC)
¨Max. power 90Watt
Weight and Size
¨System approximately 2.09 Lbs
¨System Dimensions :7.79 x 6.34 x 2.44 inch
Operation System
¨Windows XP
¨Windows 98/2000
¨Windows NT
¨Windows Me
¨Linux
Color
¨ Silver or Black
I will get, and hook it up to a 7" LCD plus a wirelees keyboard and a CB external speaker
Take care,
Az
Old Jan 31, 2004 | 05:37 AM
Dershum's Avatar
Dershum
I think you could technically fit that in a DIN slot (the smaller one that is)...you'd just have to build a mounting bracket for it.
I think the biggest problem with this is the power switch being right up on top, it'll make turning it on and off a ***** without modifying it to move that button elsewhere.
Old Jan 31, 2004 | 05:51 AM
aalzuhair's Avatar
aalzuhair
Check it again... the e PC 3 has a front power button.
Old Jan 31, 2004 | 06:09 AM
aalzuhair's Avatar
aalzuhair
Other parts needed:
Tacoma Nissan Parts
Electrical, Navigation system components, Control module, Bracket, Bracket Right 1 $9.97
Electrical, Navigation system components, Control module, Bracket, Bracket Left 1 $5.97
Quarter panel, Interior trim, Escutcheon, Black, Black 1 $8.28
Quarter panel, Interior trim, Box, Bracket, Bracket 1 $12.29
Quarter panel, Interior trim, Box, Spacer, Spacer 1 $3.09
Sub Total $47.88
Old Jan 31, 2004 | 08:40 AM
MY350Z.COM's Avatar
moved
Old Jan 31, 2004 | 09:27 AM
aalzuhair's Avatar
aalzuhair
Before the Move,
Someone replied by saying, that this mini PC is a bit over priced ($1200 with DVD) and provided me with a link to check other mini PCs configurations.
Anyway, I did. The only problem I found that the other configuration is about 4 inches longer, which I think wouldn’t fit the DIN slot, and the case did not have a slot for a PC card, which can be used for a Bluetooth keyboard or cell phone or whatever.
Take care,
Az
etkms
Jun 19, 2022 06:30 PM
StreetStandard
Videos
Feb 4, 2016 09:44 AM
