Where Are Factory Amps For Bose
there are two amps, one for the speakers and one for the sub
the one for the speakers in in the back left trunk area, beside the spare tire. It's mounted under a metal bracket that's under the rigid foam spacer.
the one for the sub is in the sub compartment. if you look at the front of the sub, it would be on the top left, screwed into the sub mounting plate.
the wiring runs along the b-pillar on the drivers side and then under the rear strut bar.
to "really" get to them, you'll pretty much need to strip out the interior trim panels.
Here is a link to some pictures showing how to get to the main Bose amp in a 350Z coupe.
http://carstereohelp.com/stereoremov...0zBoseAmpR.htm
