Focal 165W ($569.00) Will They fit?
Old May 31, 2004 | 09:24 AM
zand02max's Avatar
zand02max
Default Focal 165W ($569.00) Will They fit?
I am debating two different componet speakers, help me decide.
1. Focal 165W
Sensitivity: 92.5 dB
RMS Power Range : 100 Watts
Peak Power Handling: 200 Watts
Frequency response: 50-22000 Hz
Diameter: 6.5 Inch
2-way separate system, possible bi-amplification.
165mm (6-1/2") midbass, 40mm (1-3/8") v.coil, 100mm (4") magnet.
TN 51 tweeter.
2-way separate crossover with high end components.
24 dB/oct. (3kHz) with adjustable levels.
Max. power handling: 200W.
Nominal, power handling: 100W.
Sensitivity (2.8 V/1m): 92.5dB.
Frequency response: 50Hz-22kHz.
http://www.onlinecarstereo.com/CarAu...roductID=11712
2. Focal 165K- $499.00
Frequency response: 70-22000 Hz
Diameter: 6.5 Inch
Two way separate kit
6.5" Woofer
1.5" voicecoil
4" magnet
TN 52 tweeter.
Dome- inverted tioxid 5 dome
18dB/oct Seperate crossover
Adjustable tweeter and midrange level
Max. power handling: 200Watts
Nominal, power handling: 100Watts
Sensitivity : 92.5dB.
Freq response: 70Hz-22kHz
Grill Included
http://www.onlinecarstereo.com/CarAu...roductID=13571
Will the 165W fit in the factory doors?
The only difference I see, is the 165W's can have bi-amplification. I believe those are the high end ones with kevlar linings, is that correct?
Thanks for any help.
The speakers will be powered by a Rockford Fosgate Power 800.4.
Old May 31, 2004 | 10:34 PM
BoostTed's Avatar
BoostTed
I have the 165w3 in my car. And i have the 6.5" woofers in the stock location. The 165W have a different speaker cone than the 165K. The W's are kevlar I believe, and a different crossover as well.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
