Wiring Help
Ok, trying to install an aftermarket alarm.
I have the service manual and figure I can tap the wires going into the BCM (body control module) to trigger the doors, horns, trunk, etc..
Tested the connections with a multimeter and voltage does not change when any door is opened/closed.
Anyone know what wire I need to tap into for the door open & close, Trunk, horn, parking lights, and dome light?
Only one I can find is the ignition and brake.
12volts white/blue + ignition harness
Starter white/red + ignition harness
Second Starter white/green + ignition harness
Ignition black/red + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory white/black + ignition harness
Second Accessory N/A
Keysense black/red + ignition harness
Power Lock red - driver door module in door
Notes: These are the driver door key cylinder wires. Meter the wires while turning the key in the driver door.
Power Unlock lt. blue - driver door module in door
Notes: These are the driver door key cylinder wires. Meter the wires while turning the key in the driver door. Unlock requires a double pulse.
Lock Motor purple 5wi wht plug, pin 30 at BCM
Notes: The BCM (Body Control Module) is in the driver kick panel below the fuse box.
Unlock Motor yellow 5wi wht plug, pin 23 at BCM
Parking Lights+ red/blue + driver kick panel
Parking Lights- N/A
Hazards green/red - brn plug, pin 61 at BCM
Turn Signal(L) green/white + wht plug, pin 22 at BCM
Turn Signal(R) purple/white + wht plug, pin 21 at BCM
Reverse Light lt. green + driver kick panel
Door Trigger white (L), pink (R) - wht plug, pin 14, 10 at BCM
Notes: Use both wires and diode isolate each.
Dome Supervision comes on with unlock
Trunk/Hatch Pin red/white - wht plug, pin 18 at BCM
Hood Pin lt. green/black - pin switch under hood
Trunk/Hatch Release pink - brn plug, pin 76 at BCM
Notes: For hatch release can also use purple (+) in a white plug, pin 19.
The fuel door release is blue/red (-) at the switch on the dash.
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock single pulse power unlock
Tachometer NOT black or white/blue ac any ignition coil
Wait to start N/A
Brake Wire pink/blue + brake pedal switch
Parking Brake purple - parking brake switch
Horn Trigger green/black - steering column
Immobilizer Bypass Module: Required: Yes Type: Transponder Part #: 556U or 555U
Second Ignition N/A
Third Ignition N/A
Parking Lights- N/A
Wait to start N/A
350Z_Al
Oct 29, 2020 07:44 PM
bcoffee20
Nov 19, 2015 06:39 PM
Beater350z
Sep 9, 2015 03:36 PM
