Xenarc 700 TSV BAD USB
Old Jul 25, 2004 | 08:05 PM
SIX's Avatar
SIX
Exclamation Xenarc 700 TSV BAD USB
Guys FYI,
I just recieved my screen and guess what. Bad USB cable. I did some research and found out that the Maker of the USB cable produced A batch of bad cables. Basicly, the USB wires are in the wrong order. The only way to fix the issue is to cut the usb cable and solder the correct wire Diagram. Dont get me wrong the screen is Awsome, for the exception of the USB cable. So now I am waitng for a reply form Xenarc on the Issue.
A good site that introduces this problem:
http://www.modthebox.com/review258_4.shtml
Old Dec 5, 2004 | 09:42 AM
BlueDragonZ's Avatar
BlueDragonZ
Default Re: Xenarc 700 TSV BAD USB
Originally posted by SIX
Guys FYI,
Did you ever get a resolution from Xenarc pertaining to this issue or did you just resolder it yourself? I'm looking at several Xenarc screens and possibly this one. I'm also looking at the YV and TS model as well. Do you know if the TS also has the same problem with the USB? Thanks.
Old Dec 8, 2004 | 07:33 PM
SIX's Avatar
SIX
Was checking my connections again and found out that My USB cable connecting to the Motherboard was Bad. Not the Usb cable form Xenarc. They were prompt on responses to the Issue and offered to help in any way.
Justin100
Nov 25, 2021 06:26 AM
2ndchanceZ
Oct 26, 2015 08:03 PM
