Make a line/aux in for your 2003 Bose headunit – step by step guide
Old Nov 10, 2008 | 01:47 PM
  #121
G-Man.uas's Avatar
G-Man.uas
Originally Posted by SteveZ
Given the BOSE unit has a dealer replacement cost of $2400 USD, in my '04 and a refurbished unit is about $650 USD, I'd just pull the unit before I did this mod, and sell it. It lacks adjustment in output, it just doens't sound that great.
Buy the replacement double-din center console, drop in Infinity Kappa speakers, or get the adapter for 2 ohm OEM speakers, put in a nice HU.
For people out of warranty I would not be surprised if you could sell the existing unit for almost $500 USD, buy the $200 center double DIN which is very well done, includes A/C controls for either '03-'04 or the updated '05 forward style. Apply the rest toward a kickass HU pre-wired for iPod, SAT, and/or for those w/o NAV, drop in a double DIN unit with NAV.
After you've done this "mod" (hack) the BOSE unit has zero resale value, and when it dies (a frequent problem now after 4-5 years nothing to do with this mod), then you have to either suck up the price of new unit, or go the replacement console route as suggested above.
Just pointing out "con" side of the pros/cons of wiring up an AUX input in this manner.
Who are you still preaching to? It's like your 3rd post over the last few years saying the same thing This is a great thread for those people who want a quick and easy install so they can use their MP3 players. I'll bet for most of the people replying here the Bose works and has acceptable capabilities. Mine plays CDs, tunes into radio frequencies just fine and sounds perfect for my needs. I'm gonna do this mod myself as soon as I get the chance. If the Bose dies, it dies, but I'm certainly not going to spend several hundred dollars for the ICE setup you recommend.
Great thread btw guys
Old Nov 30, 2008 | 04:40 AM
  #122
alessandro+'s Avatar
alessandro+
I got everything working correctly plus the srping and arm mod, so now no cassette is needed in the slot.
As per the tape error issue, I confirm that pressing eject before turning the ignition on does resolve the problem.
Thank you who posted and refined the post!
PS: the mod works on Italian spec head units, which as far as I know are Euro/UK spec. In other words, you UK and French blokes can try it out.
Old Dec 3, 2008 | 07:49 PM
  #123
boondocksaint's Avatar
boondocksaint
Just finished with the whole process! It worked on my 2003 350Z Touring Ed BOSE stereo. Thanks a bunch!
Old Dec 29, 2008 | 06:39 AM
  #124
dcash5's Avatar
dcash5
[IMG]http://i89.photobucket.com/albums/k226/Wolf823/350z/Bose%20Aux/Bose5.jpg[\IMG]
Couple of questions. You state you solders this in 3 points. Obviously I can see the red is soldered to R-CH but is the clear soldered to both the A-GND and L-CH.
Secondly would this work with a phono to 3mm Jack option for a slightly cleaner install.
Many thanks
Dan
Old Feb 25, 2009 | 04:08 PM
  #125
mazymus's Avatar
mazymus
does something like this exist for base 2003 non-bose system? tx
Old Apr 28, 2009 | 05:35 PM
  #126
durt's Avatar
durt
Does anyone have the pictures? They don't seem to be showing up anymore. Thanks.
Old Jul 1, 2009 | 06:03 AM
  #127
m1keyboy's Avatar
m1keyboy
*Bump*
I'm going to attempt this during the next few weeks (UK Z - it's my only choice!). To the people who've already done it - where did you route the cable after the installation? Any pics of some clean installs for this?
Old Aug 10, 2009 | 05:30 AM
  #128
bigaudiofanatic's Avatar
bigaudiofanatic
There are no more pics in the first page!
Old Sep 11, 2009 | 09:07 AM
  #129
dowork84's Avatar
dowork84
Default issues
Hey i got everything hooked up lines are clean cut, but for the tape error issue mine seems not to be helped by the pressing of the eject button. It tries to read side 1 switches to side 2 then says tape error. I can hear the music come through while it plays so i know its wired and i def broke the connection lines. Any suggestions, thanks
Old Oct 30, 2009 | 09:09 AM
  #130
lhassall's Avatar
lhassall
Just added an aux-in to my 2004 UK head unit with help from this guide and thought I'd share my slightly easier and reversible method.
As someone else pointed out there are 3 larger solder points for L, R, and Ground in the top-right of this picture:
____________________________________________________________ ___V____V____V
So I tried connecting up my cable up here and didn't break the PCB tracks. The result? It works perfectly!
There's no electrical components between the suggested soldering points and these, and there's actually a hole in the bottom of the head unit right next to them. You might be able to connect your cable through this hole without opening up the head unit, although you would need to support the cable somehow. I routed the cable as per the original guide.
I'm using a cheap cassette adaptor to fool the mechanism, but I've removed the head/cable and greased the internal gears so it runs very quiet. Before I removed the head I got a tiny amount of hiss from the cassette audio circuit, but only at very high volume with no music playing. Another way around this would be to just turn on Dolby. This won't affect the sound of the line-in because the Dolby chip is upstream on the cassette unit.
So if anybody is worried about cutting the PCB tracks you don't need to, and if you're soldering skills are not so hot you can solder the wires in an easier position. You can add an aux-in without sacrificing tape playback at all and I hope this encourages more people to do it
Old Nov 8, 2009 | 03:43 AM
  #131
DJK's Avatar
DJK
Old Jan 15, 2010 | 03:40 PM
  #132
TopGunn's Avatar
TopGunn
Just completed this last night. Sounds AWESOME. The tape idea with removing the spring and metal mechanism worked flawlessly.
Thanks again!
Old Jan 30, 2010 | 11:25 AM
  #133
spiechu's Avatar
spiechu
thanks
Old Feb 25, 2010 | 08:43 AM
  #134
penfolduk's Avatar
penfolduk
why the need to make the cuts in the 3 pcb tracks
Old Feb 26, 2010 | 12:06 AM
  #135
lhassall's Avatar
lhassall
See my post above... You don't need to.
I guess the original poster was worried about noise from the tape circuit but as long as there's no tape in (or no head in the cassette adaptor) you won't hear it. Even if you did get a small amount of hiss you could just turn Dolby on.
Old Feb 26, 2010 | 12:15 AM
  #136
penfolduk's Avatar
penfolduk
ive done it the other way using the 3 contacts at the top right but gettin loads of feedback/interference on left channel gonna try the cutting method
Old Feb 26, 2010 | 11:02 AM
  #137
lhassall's Avatar
lhassall
Must be your routing of the cable or poor connection on the ground wire. Are you sure you haven't connected the Ground and Left wires the wrong way around? Or maybe damaged the insulation between them?
Old Apr 29, 2010 | 09:23 AM
  #138
estrov's Avatar
estrov
Originally Posted by DJK
This is the way to go. 1 Hour install and you maintain the CD changer and tape player.
Old May 21, 2010 | 09:27 AM
  #139
skandalous's Avatar
skandalous
Has anyone gotten this mod to work on a Non-Cassette Bose unit? Mine did not come with a cassette deck. TIA
Old May 24, 2010 | 08:11 PM
  #140
STL 350Z's Avatar
STL 350Z
+1...
