Problems hooking up Xbox
Old Dec 1, 2004 | 03:05 PM
black-hawk's Avatar
black-hawk
Originally posted by garagetwothree
are the people getting noise hardwiring into the cig lighter? If so this may not be a good idea. You get noise from the cig power supply from the ignition system. Some companies make shift lights that just plug into the cig lighter..lol. Others that may not be getting noise may just have a better inverter. MY suggestion is to run a new power wire from the fuse box and ground it off the chassis with the shortest wire possible.
With my inverter, I have a cig adapter, and an adapter that can hook onto the battery. No matter which one I use, I still get video and audio interference.
Old Dec 4, 2004 | 06:42 PM
the7ferret's Avatar
the7ferret
might also want to upgrade your factory ground at the battery. I got the grounding kit and added an extra chassie ground because I am working on a big system and want a good ground
Old Dec 7, 2004 | 04:42 PM
LaPuLaPu's Avatar
LaPuLaPu
My power convertor was causing alot of noise. I went through three different units until I found the Monter performance car 150watt convertor. http://www.monstercable.com/caraudio2/PerfCar.asp
I bought mine at Best Buy.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
