back up camera?
Old Jun 27, 2005 | 01:30 PM
onii's Avatar
onii
Default back up camera?
I want to get a backup camera installed onto my kenwood ddx7015...anyone have any idea? i dunno where to get a camera. If possible, it would be nice if it automatically switched to the camera when i put the car in reverse. any ideas would be appreciated.
Old Jun 27, 2005 | 01:39 PM
rjpaterson's Avatar
rjpaterson
Z Enthusiast
I bought mine off of ebay.
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=5773649047
Really good quality and easy installation.
Old Jun 27, 2005 | 01:47 PM
onii's Avatar
onii
how did you mount it? i want it as concealed as possible. got pics? i really dont want a thing stickin outta the back of my car.
Old Jun 27, 2005 | 02:06 PM
rjpaterson's Avatar
rjpaterson
Z Enthusiast
I mounted it thru my license plate. You can see a pic here
http://www.rippedzone.no-ip.org/Inte...ifications.asp
Old Jun 27, 2005 | 02:09 PM
onii's Avatar
onii
so you cut a hole in the rear bumper? how is it attached inside? do you have a bracket mounted on something?
and i dunno bout cuttin a hole in the license..
Old Jun 27, 2005 | 02:15 PM
rjpaterson's Avatar
rjpaterson
Z Enthusiast
Yes, there I had to cut a hole in the bumper behind the plate. The entire camera's outer shaft is threaded and has the appropriate spacers to get it angled just right.
I'd rather put a hole in the plate than a hole in the bumper that's visible.
Old Jun 27, 2005 | 02:28 PM
onii's Avatar
onii
i was hopin to get somethin like the jdm camera that's tiny and fits up above the plate.
Old Jun 27, 2005 | 05:37 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
www.supercircuits.com
I've bought eight or ten cameras from these guys. Find one that comes with a "U" bolt mount, that's color, and waterproof. Depending on the resolution it should run you $40-$200 with the sweet spot being about $40 rather than $200. Understand that you're using this in a car to glance at from time-to-time so you don't need 700 lines of resolution and 0.001 Lux sensitivitiy.
Fine one with 300-400 lines of resolution and 2-3 Lux.
Old Jun 27, 2005 | 10:35 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
the one from Ebay link would work ok.
Old Jun 28, 2005 | 04:56 AM
onii's Avatar
onii
gonna take a look at the supercircuit ones...hopefully they'll be smaller than the ebay ones. i want to do a total conceal install...not feelin the hole thru the license plate thing.
Old Jun 28, 2005 | 05:06 AM
onii's Avatar
onii
the smallest one i found seems to be the BOSS CAM10. however..i cant find actual specs of it anywhere..
or this one?
http://www.etronics.com/product.asp?...ore=&catid=382
that last one is 0.98" x 2.12"...smallest so far
Old Jun 29, 2005 | 12:17 AM
unstable's Avatar
unstable
Check the Eclipse one by Fujitsu...
Old Jun 29, 2005 | 04:17 AM
onii's Avatar
onii
would the eclipse cam hook up to my kenwood HU?
holy damn! it's $200??
how bout this one
http://www.mobilesoundworks.com/Prod...VAC%2DRV5000NC
Old Jun 29, 2005 | 09:10 AM
unstable's Avatar
unstable
how bout this one
HAHAHA... yea I didnt say the eclipse was cheap, but it is a good camera and comes with the brackets to conseal it. As to if it goes with your HU I really have no idea but I don't see why it wouldn't, for the most part they're just A/V connectors. Good luck.
Old Jun 29, 2005 | 09:15 AM
onii's Avatar
onii
any idea how it hooks up? im lookin to get something that can isntall like the jdm one...without cutting a big hole in the bumper.
Old Jun 29, 2005 | 09:44 AM
unstable's Avatar
unstable
If I remember correctly it has a small bracket you just screw in where ever you want to place the camera... as for the wires I really don't know but I'm guessing you may have to drill a small hole somewhere to feed them through...
Old Jul 30, 2005 | 09:31 PM
whitew's Avatar
whitew
Smile Backup Camera for NAV
How can I hookup a backup camera to my 2003 350Z NAV system? I don't want to buy new monitor.
Thanks
Old Jul 31, 2005 | 06:42 AM
rjpaterson's Avatar
rjpaterson
Z Enthusiast
WhiteW,
This is the module I used with my OEM screen. It expensive but it works great.
http://www.mobilevideo4less.com/Merchant2/merchant.mv?
It provides 2 video inputs. One is autosensing which I have my reverse camera connected to. When I put my car in reverse the camera gets powered and the video automatically switches. The other inout can be used for any other video source (ie forward looking camera, DVD, PS, Xbox etc....)
Old Jul 31, 2005 | 07:02 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Originally Posted by rjpaterson
Looks like the site is down or at least broken now. Sounds easy enough to make - a two position relay which switches with the +12V power for the backing lights. I like.
Mounting the camera is a *****. I'm not certain how well the po-po is going to like a one plus inch hole cut thru the license plate. There arn't any pin-hole rear-view cameras that I've found. Plenty of normal cameras for the front plate but none for the rear.
I went thru SuperCircuits.com and found only normal view cameras. I had a spare normal camera and velcro'ed it to the back to test and it didn't work - the mind doesn't do the looking foward and seeing backwards thing.
Old Jul 31, 2005 | 06:17 PM
whitew's Avatar
whitew
Smile
I got the link work. It lead me to here: http://www.mobilevideo4less.com/cameras.html.
I think there may be incompatibility problems between some cameras and the NAV monitor.
I'm still looking in to it. Hope to get more responses.
Thanks
