Camber Adjustment??
Old Dec 17, 2004 | 09:19 PM
mbonanni1856's Avatar
mbonanni1856
Default Camber Adjustment??
Is there any factory camber adjustment on the Z? I just got some Hoosier Autocross tires and I want them to last as long as possible, as well as get proper grip. If so, what do you guys set it at. I noticed that Stillen has rear camber and toe adjusters, but no front. Stupid question...but what is the difference between camber and toe? I am running SM2 next season due to a supercharger, so what do you suggest for suspension set up? Any help would be greatly appreciated. Thanks.
Old Dec 18, 2004 | 08:48 AM
Eagle1's Avatar
Eagle1
http://www.advanceautoparts.com/engl...0021201ay.html
http://www.michelinman.com/care/tip3.html
Check these out for a quickie primer on camber, caster and toe.
Performance Nissan Racing offers an adjustable set of front upper control arms to adjust camber, and they are terrific and easy to use.
Old Dec 18, 2004 | 09:45 AM
mbonanni1856
Thanks.
Old Dec 18, 2004 | 09:59 AM
dwnshift's Avatar
dwnshift
www.350evo.com
Designed, tested and proven through motorsports and absolutley the best quallity.
Do a search on thsi forum on our front upper control arms.
Cheers
BJ@350EVO.com
Old Dec 20, 2004 | 08:19 AM
mpowers's Avatar
mpowers
Bump for BJ,
I have had mine for about 12k now with no problems and they bolt right on. On my car a negative 3.6 degrees out of the 350EVO upper arms!
HoBrahYouStink
Jun 24, 2016 10:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
