weight
Old Jan 12, 2006 | 07:34 AM
  #101
Vamos_Rafael's Avatar
Vamos_Rafael
weight issue = always a sensitive one to tackle for the Zed car...
but its always nice to see a discussion going for 5 pages in motorsports section
Old Jan 12, 2006 | 10:30 AM
  #102
FritzMan's Avatar
FritzMan
[QUOTE=EnthuZ]
Originally Posted by FritzMan
I'd agree about increased stiffness.
My harness bar must has pulled the two B pillars in a good 1/4" - 1/2". QUOTE]
May I ask which harness bar did that?
Avalon
Old Jan 12, 2006 | 10:36 AM
  #103
EnthuZ's Avatar
EnthuZ
Damn, that's pretty sh*ty tolerances.
Old Jan 12, 2006 | 10:55 AM
  #104
BA Cutler's Avatar
BA Cutler
The Z? Or the bar?
BC
Old Jan 12, 2006 | 11:21 AM
  #105
Stack's Avatar
Stack
Originally Posted by Mr.Jadkowski
Well, if the rules clearly state that a harness is allowed (which they do) then you wouldn't have any ground to stand on. It's like running in BSP with a stock car and protesting that everyone else has modified cars. If the rules state that you can make the modification, it's your own fault if you haven't.
OK... this is why I'm certainly in no rush to run with SCCA (assuming we're talking about SCCA). **WARNING** Logical progression follows
--OK... after going through a few different sections in the 2006 GCR, there is no logical progression
The problem is the GCR does not specify any harness installation guidelines (negligent IMO). So the installation is left open to interpretation... however, the section on driver restraints reads as follows:
3.3.1 Driver Restraints
Seat lap belts are required in all cars, and must be installed in cars with passive restraint systems that do not include a lap belt. Installation and the use of shoulder belts or harnesses is strongly recommended,
ok, this seems to be a holdover from the formative years when cars didn't come with shoulder belts. The recommendation IMHO is not referring to what is today commonly referred to as harnesses because of the following:
however non-factory upper body restraints may only be used in open cars, cars with targa-tops in the open position, or cars with T-tops in the open position when two conditions are met:
a. The roll structure must meet either the requirements of Appendix C or Section 18 of the GCR.
b. The top of the roll structure may not be below the top of the driver’s helmet when the driver is in the normal driving position.
So how does this apply to the stock class? Unless someone's open top car meets the above requirements, they are not allowed to run harnesses. The only addition to the above rules is this:
G. Roll bars and roll cages may be added (See Appendix C). It is strongly recommended that roll cages be constructed according to Section 18 of the GCR, though they must be bolted (not welded) into the automobile and be contained within the driver/passenger compartment. Roll bars may be welded in. A roll cage has more
than four attachment points to the body or frame, or has bracing both fore and aft of the main hoop.
H. Driver restraints as outlined in Section 3.3.1 are allowed. Seats may not be cut to allow for the installation of alternate seat belts or harnesses. Passive restraint systems may not be removed. A horizontal “harness bar” may be used as part of the installation hardware for allowed driver restraints.
Allowed driver restraints, depending on how you interpret section 3.3.1, means factory only belts if in a non convertible or open top car with roll-over protection.
It may serve no other purpose (e.g., structural enhancement).
This is SO contradictory as to be laughable... If a roll bar or cage can be added, it most certainly will add 'structural enhancement' even if it doesn't attach to suspension pick-up points (i.e. being contained in passenger compartment). So my earlier statement holds true: as long as the harness bar is not attached to the strut towers, or it's somehow triangulating the rear of the car, you should be safe and you should fight any protest against it.
BTW... rules can be read online here: http://www.scca.org/_filelibrary/File/2005SoloRules.pdf
Old Jan 12, 2006 | 11:22 AM
  #106
FritzMan's Avatar
FritzMan
I think it's more intentional rather than poor workmanship.
Old Jan 12, 2006 | 11:40 AM
  #107
EnthuZ's Avatar
EnthuZ
Originally Posted by BA Cutler
The Z? Or the bar?
BC
In my experience, ALL 350Z's of all years have exemplary consistency in their body building. I've allowed for potential variances in my bars "B" pillar mounting, but no one has needed to apply any corrections.
Now, isn't the topic WEIGHT?
Old Jan 12, 2006 | 11:45 AM
  #108
del105's Avatar
del105
15 f125
Yes it is a gray area except when the manufaturer says in writing that it increases the structual ridgidity of the car. At which point that harness bar moves from being gray area to being illegal.
I think the rules are very straight forward on this. SCCA wants you to be able to use one but wants to limit the options without having to write a 900 page dos and don't of harness bars in stock class.
I wouldn't worry about it unless you are planning on going to a prosolo or national tour at which point it is "possible" you might get protested.
Here is how I see it. In my class (F125) the rules are far more murky in terms of legal parts and modifications. I feel like if something in the rulebook is not explained well enough then it is legal until the protest commitee says it isnt. This is different than doing something explictly illegal until you get caught which is cheating.
Old Jan 12, 2006 | 11:53 AM
  #109
Stack's Avatar
Stack
Of course, the GCR it states that if its not written as allowed, then it is illegal... so by your own standard, what you are doing is cheating (tongue planted firmly in cheek)
13.1 AUTHORIZED MODIFICATIONS
If a modification is not specifically authorized in this or previous
sections of these Rules it is not allowed. It is not permitted to use
illegal parts even if they have been set to stock specifications.
Old Jan 12, 2006 | 12:19 PM
  #110
del105's Avatar
del105
15 f125
exactly.
Old Jan 15, 2006 | 04:32 PM
  #111
BA Cutler's Avatar
BA Cutler
Yeah, let's go back to weight. We don't even want to start a tolerance consistency conversation.
BC
Old Jan 15, 2006 | 05:06 PM
  #112
drivesolo's Avatar
drivesolo
BC
Here's a weight question that I had.
Is the '06 Z heavier than the previous model year Z's? I was on Edmunds and it lists the '06 350Z 'bout 100lbs heavier in compariable trim levels than previous model years. If this is correct; where is the extra weight coming from. It can't be just in the wheels alone.
sales@czp
Sep 23, 2019 03:30 PM
tm9293
North East Marketplace
13
Oct 17, 2015 09:14 PM
1973camarolt
Drivetrain
Oct 11, 2015 01:26 PM
Shane86
Sep 17, 2015 05:33 PM
