What is the best wheel size for the track?
Old Jan 15, 2007 | 02:04 PM
pgibbs's Avatar
pgibbs
Default What is the best wheel size for the track?
I know the 350Z Track model comes with 18" wheels, but I thought I'd solicit opinions from this forum. Thanks.
Old Jan 15, 2007 | 02:07 PM
Sean's Avatar
Sean
1/4 mile?
Old Jan 15, 2007 | 02:09 PM
pgibbs's Avatar
pgibbs
Recreational road course use. I am starting to take my car to NASA open track events and was curious about changing my wheels. I'm on stock 17s right now.
Old Jan 15, 2007 | 02:12 PM
Sean's Avatar
Sean
I can't help you with that, but read this.
http://www.sportcompactcarweb.com/pr...n_350z_part_2/
DavesZ#3's Avatar
DavesZ#3
Smaller wheels are lighter so you will see a lot of the track guys running 17" wheels.
Old Jan 15, 2007 | 02:20 PM
pgibbs's Avatar
pgibbs
what size wheels are those on your car in the pic (on the track)?
Old Jan 15, 2007 | 02:22 PM
skidmarq's Avatar
skidmarq
17" wheels would be the easy answer, and likely the correct answer unless you run a brake kit that can not fit underneath that diamer of a wheel.
Of course you will likely not need a brake kit that large unless you are running high HP and running courses that have many high speed sequential braking zones.
Long story short, we will probably need more information before being able to supply an answer due to the variables that come into play...
Old Jan 15, 2007 | 02:51 PM
betamotorsports's Avatar
betamotorsports
Actually, Hoosier has announced a 275/35-15" tire that will be 22.8" in diameter and 11.2" wide. Custom rims should weigh about 13 lbs and the tires would be about 16 lbs. Figure 30 lbs. total for your wheel and tire combination. That would be a perfect track setup if you can clear a nice set of brakes, like... maybe 1.375" thick, 12" rotors with some PBR aluminum calipers?
Old Jan 15, 2007 | 03:42 PM
DavesZ#3's Avatar
DavesZ#3
Those are 19". They're my street wheels/tires but I will use them in HPDEs. They are actually lighter than my stock 18" wheels/tires were.
Old Jan 15, 2007 | 03:52 PM
DROPPEDIT2WCE's Avatar
DROPPEDIT2WCE
lenso's and hoosiers! mmmm tasty treats
Old Jan 15, 2007 | 06:21 PM
jun14scr's Avatar
jun14scr
i prefer the tire sizes for 18s right now.
Old Jan 15, 2007 | 07:34 PM
first350's Avatar
first350
sounds interesting...what 15" rims will fit OE non-brembo brakes?
-Peter
Old Jan 15, 2007 | 08:17 PM
WA2GOOD's Avatar
WA2GOOD
-Peter
+1.... I dont think it is possible.
pgibbs, Not sure what you are able to run as far as rules for your class, but i have tracked most aplicable wheel sizes and widths. Hands down, I prefer a 265 to a 285/30/18 for the front and a 295 to a 315/30/18 for the rear on these Z's. 18" wheels work the best IMO, for the size of brakes we use and tire width we need. I like a 18x8.5" to a 18x9.5" front wheel, and a 18x9.5" to a 18x10.5" rear wheel.
Old Jan 15, 2007 | 08:26 PM
pgibbs's Avatar
pgibbs
great info. Thanks!
Old Jan 16, 2007 | 12:08 AM
adrianko43's Avatar
adrianko43
If they will fit over your brakes, i say go for 17's becuase there is a wider selection of r-compound tires, and other sporty tires.
Old Feb 11, 2007 | 10:17 AM
glennmead's Avatar
glennmead
I went from 18" to 17".
1. Tires are cheaper
2. Wheels are lighter
3. Lower center of gravity
4. Higher effective gear ratio for more acceleration
Old Feb 12, 2007 | 05:57 PM
scubasteve's Avatar
scubasteve
I've got some 17's, also. All for the same reason as glennmead.
Old Feb 13, 2007 | 12:58 PM
thefastestz's Avatar
thefastestz
Ditto.
burglapfd
Dec 6, 2020 01:04 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
kyin
Oct 15, 2015 05:54 AM
Depravity
Oct 1, 2015 04:49 PM
