Camera mount
Old May 12, 2007 | 12:38 PM
eeZee's Avatar
eeZee
Default Camera mount
Please post pictures of your camera mounts. I'm looking for ideas for autocross recording.
Thanks.
Old May 12, 2007 | 12:53 PM
DavesZ#3's Avatar
DavesZ#3
Get a CruiseCam
http://www.soloperformance.com/Shopp...0/Default.aspx
Old May 12, 2007 | 02:06 PM
StylesCD's Avatar
StylesCD
Originally Posted by DavesZ#3
wel either that or if you were as ghetto as me you just duct tape your camer to your dashboard
Old May 12, 2007 | 02:33 PM
first350's Avatar
first350
I have lots of stuff from this company: http://www.chasecam.com/news.htm
they have a 3 suction cup mount that holds a lot of wieght
Old May 12, 2007 | 02:46 PM
DavesZ#3's Avatar
DavesZ#3
Hell, there's not enough duct tape on a roll to hold a camera down while being slammed around the course. Somehow, I'm surprised that passes tech.
Old May 12, 2007 | 04:46 PM
justinrlamb00's Avatar
justinrlamb00
I'll try to take some pics of the mount that I made. I took 2 pieces of PVC pipe and put a "t" between them and capped off the "T". I put a bolt and a nut through the T that is the size of the hole in the bottom of the camera. Then I drilled holes in the PVC pipe so that it would line up with the headrest, and then I took the headrests off and put them through the "mount" It worked AWSOME, and it only cost about $7 max.
Old May 12, 2007 | 05:14 PM
justinrlamb00
its ghetto, but it works, lol...pics:
Old May 12, 2007 | 05:23 PM
PDX_Racer's Avatar
PDX_Racer
I have one of their 3 suction cup mounts (4 years old now), and it works very well.
Old May 12, 2007 | 07:21 PM
Marc Mc's Avatar
Marc Mc
I have the IO Port (www.ioportracing.com) and it works well. The multi adjustment features allow you to position it on harness bar and roll cage easily....under $100.
Marc
Old May 13, 2007 | 05:02 AM
Kirkster's Avatar
Kirkster
ChaseCam is the way to go...
I have one of their 3 suction cup mounts as well as a bullet cam and a PDR100 DVR. First rate all the way...
Old May 13, 2007 | 05:35 AM
TheProfessional's Avatar
TheProfessional
I just bought my setup in April, I have Adobe premier for editing.. hopefully I will get some good stuff out next week after zdayz
https://my350z.com/forum/showpost.ph...3&postcount=52
One note to you guys... you NEED to get a Wide end conversion lens for your camcorder. I noticed we are missing a lot of the angles when you use the normal lens only. I picked up the Sony VCL-E07A for under $50 at Best Buy.
The difference could mean having the view including both side mirrors versus just seeing through the front window and the lane in front of you.
Old May 13, 2007 | 07:29 AM
eeZee's Avatar
eeZee
Thanks everyone.
I am looking just for mounts, not camera systems, as tempting as they are...
That ChaseCam 3-suction cup with extension looks like it would do the trick for my digicam. I'm hoping to mount it on the inside of the hatch window between the seats. Any comments on vibration in the videos?
Manfrotto makes one too and it has additional leg to support the suction mount to reduce vibration. Thanks.
Old May 13, 2007 | 07:46 AM
imonlykidden's Avatar
imonlykidden
chasecam...... google it.
Old May 13, 2007 | 07:53 AM
PDX_Racer's Avatar
PDX_Racer
Originally Posted by eeZee
Thanks everyone.
Vibration isn't too bad, even right at the start. I've got a couple of videos, one from my SpecV and one from my Z. My camera is mounted on this: ChaseCam Window Mount, Triple Suction Cup Base
SpecV: 2002 Nissan Sentra SE-R SpecV
350Z: 2005 Nissan 350Z Track Model
Old May 13, 2007 | 11:03 AM
mistico's Avatar
mistico
Where do the suction cams go? On the passenger window?
I want one for mynext event as well.
Thanks.
Old May 13, 2007 | 02:29 PM
eeZee's Avatar
eeZee
That looks like the placement I'd like. Do you have it mounted on the hatch window? Do you have a picture of the mount inside your Z?
I want to use this for my digicam, so I'm hoping there's enough stick on the mount for the camera to sit upright, but it doesn't look that way.
Old May 13, 2007 | 02:46 PM
tmak26b's Avatar
tmak26b
I kind of have a cheesy setup. I have a lipstick camera mounted under the rear hatch window. It would then have a mic on the license plate and a camcorder inside the car with input feature to capture it. I think the whole setup was $150. As long as the sun isnt too bright, I can usually get decent videos. http://www.youtube.com/watch?v=24ziLMi2X-8
Old May 13, 2007 | 02:58 PM
mistico's Avatar
mistico
Ok, what was I thinking when I asked that question considering the answer was already on this thread?
Those look like they would do the job great.
Old May 13, 2007 | 03:04 PM
PDX_Racer's Avatar
PDX_Racer
I don't have any pictures, sorry. The camera mount has two of the suction cups as tight to the high-mounted stoplight as possible, then the camera is mounted on the extension, and ends up very close to the bottom of the high-mounted stoplight. Kind of hard to describe, but if you start with the mount on the rear window, you'll see how I've got it mounted.
I'm using a Canon DV-25 camcorder.
Old May 13, 2007 | 05:13 PM
Kirkster's Avatar
Kirkster
Thanks.
I put mine here.
I have found that a video camera has some stability issues due to the amount of weight (hand held cams are heavy) that is up on the camera mount at least for autoxing it does. Also the shock and vibe has caused interesting issues with tape based systems. I changed to a compact flash system (ChaseCam PDR100) and it made a world of difference in the quality of recordings with high moments of inertial change.
The bullet cam also make a difference as there no weight to it. let me know if you want to see video output I can link in a few files. (we just finished Hatfield and McCoy trail riding with a helmet camera so I have that too)
