Hoosier A6s,what tire pressures?
Saturday will be my first autocross on A6 Hoosiers,can anyone give me any idea as to what tire pressures I'll need to start with?I'm running 285/30-18s up front and 295/30-19s in the rear on light weight Enkie wheels on a stock 07 Nismo Z.
You check pressures after each run to keep them where you believe they work the best. If the cycle is real long I'll wait until it's almost time to run instead of right after I get back.
Are you planning to run with MidSouth SCCA at Memphis Motorsports this weekend?
I'd like to see what the Nismo is capable of so I might come over. I haven't raced with MidSouth since 2005.
Originally Posted by PDX_Racer
...and still get prepared without stressing out.
I wound up running hot 45f and 40r pressures with good results.Started with 43f and 37 rear cold ending up with 45 and 40 on a cool 55-60 degree day.I did check the pressure before each run.
Ok, same question for Kuhmo 710's....
What pressures do you guys prefer? So far I've been running 36/31, 285/18's with marginal success.
(+1 on the not getting stressed out comment....I really hate it when I stage, then there is some problem on track and i have to sit there on the start line waiting....for some reason, that really psyches me out!)
you guys gonna take it up to Nashville superspeedway any this summer? i'll be up there. lemme know if ya have any problems running 285's up front, I thought about doing it on the nismos.
btw PDX did you have any sidewall flex issues runnin 275 race tires on your stockers?
Originally Posted by whitt1
I'll probably go to Nashville a few times,my daughter is out of college and working there now.
It was a lot of fun.I watched Carter come out and make one run. Whew! Jim is also stepping it up. He was really aggressive all day. There are 3 current National Champions in the region and they are happy to help people, AS, ES & ESL.
