Roll Cage Buildup - NASA racing here i come.
Old May 16, 2008 | 03:19 PM
sfarrah's Avatar
sfarrah
Originally Posted by Chebosto
nice-
are you going to do A pillar and B pillar framing?
Assuming you mean adding dimple die type gusseting there are no plans for that currently. This cage is being built so tight to the chassis that there will be several tie in points directly from the cage to the A/B pillars and roof. It can always be added down the road though.
Old May 16, 2008 | 03:21 PM
sfarrah's Avatar
sfarrah
Originally Posted by rednezz
A friend of mine said you were planning to attend the June PCA event at Harris Hill Road...will you Z be ready for that event? I would love to see it in person.
I am signed up for the event and hoping the cage is completed in time. It's a month away so I am confident I will make it to HHR. See you there! Should be fun learning a new track.
Old May 16, 2008 | 04:22 PM
n1cK!'s Avatar
n1cK!
Infiltrator!
what is the big advantage to dimple die type gussetting? does it add that much strength to the cage?
Old May 17, 2008 | 08:21 AM
betamotorsports's Avatar
betamotorsports
Its typically used to add additional support to the front hoop or the front side hoops on a vehicle with a large door opening or long A pillars.
Old May 17, 2008 | 08:51 AM
AznSky's Avatar
AznSky
awesome!!! It seems like there's not a lot of ppl that road race their Z's. Or at least as much as I thought there would be.
Old May 17, 2008 | 05:28 PM
Slow*Jim's Avatar
Slow*Jim
I was at Putnam Park all day today and there were 3 others...
Old May 17, 2008 | 05:29 PM
Slow*Jim's Avatar
Slow*Jim
Originally Posted by n1cK!
are you going to touch the sound deadening? it looks to be about 20lbs worth in the G, but it looks like such a pain in the ****!
Don't forget the dry ice trick
Old May 19, 2008 | 05:25 PM
GrandAm350's Avatar
GrandAm350
The cage looks great! The hardest part of our cage was getting the A pillar arm bent. The radius on the Z is so wide no one had the tooling to bend it. We had to find an aerospace manufacturer to bend the bars on our cars.
I also like how the did the 'coffin boxes' at the base of the main hoop and A arm bars that Impact Engineering did on our cars. Nicely done.
If you can, try tieing the cage to the frame's suspension mounts. I think Impact Engineering has some photos on their website. If not, I can post some. Fun project. Good luck and let me know if we can help at all.
-Rich
Old May 19, 2008 | 05:28 PM
GrandAm350's Avatar
GrandAm350
The only thing that worked well removing the sound deading was a torch and scrapper. We then used an organe 'citrius cleaner' that picked up all the gooey mess left behind. We tried dry ice, chisel, heat guns, etc. The torch wsa the best. Just have to watch the wires!
-Rich
Old May 27, 2008 | 11:05 AM
sfarrah's Avatar
sfarrah
Got a few more pics from SPL of the cage progress. All of the upper welds were done prior to setting the cage on the baseplates making them easy to reach. Welds look great and it is tying into the body structure nicely. Need to decide what color to paint it.
Old May 27, 2008 | 11:28 AM
mpowers's Avatar
mpowers
Very nice cage, how close are you to coming to play? And are you Texas?
Old May 27, 2008 | 01:00 PM
dmoffitt's Avatar
dmoffitt
looking VERY nice!!
Old May 30, 2008 | 10:53 AM
sfarrah's Avatar
sfarrah
Cage will take another week or two I am guessing and yes I am in Texas. Austin to be exact. I hope to run my first door to door race the beginning of August and hopefully a DE or two before that just to get used to the car, cage, HANS and harness.
Old May 30, 2008 | 11:20 AM
saberphx's Avatar
saberphx
How come you didn't remove all the brackets for the speakers and gloce compartment??? Looks like a bunch of dead weight to me. As well as the rear strut bar to replace with tubing?
Old May 30, 2008 | 11:42 AM
mpowers's Avatar
mpowers
Very cool! We often have tx's come beat us up at Road Atlanta, mostly cmc and ai-x guys. Maybe next year, since we have so many z being built, we should all gang up for the Nationals.
mpowers
Old May 30, 2008 | 02:21 PM
kuah@splparts.com's Avatar
kuah@splparts.com
Vendor - Former Vendor
Those structures stiffen the unibody... with their large cross section, we felt that it was better to leave them in than remove it and try to make up the stiffness with tubing, since the tubing will be of much smaller cross section. ie. the stock strut bar will be stiffer than a single 1.75" diameter tube bracing/between the strut towers.
Old Jun 2, 2008 | 09:54 AM
sfarrah's Avatar
sfarrah
mpowers
I'd love to go to Nationals sometime. I considered it this year for Time Trials but the current cost of gas would kill me financially. Been an expensive year prepping the car and buying all the safety gear. Maybe next year though. I hear Road Atlanta is a blast to drive-how do you like it?
Old Jun 2, 2008 | 11:40 AM
  #38
mpowers's Avatar
mpowers
Fantastic Track, you won't regret fuel & time spent to get there!
Old Jun 19, 2008 | 01:56 PM
  #39
sfarrah's Avatar
sfarrah
More pics. Welding is done, in the process of painting it now.
Very happy with the craftsmanship and how well it's tied into the chassis.
I was able to get most of the sound deadening material out with a heat gun and WD-40.
Old Jun 19, 2008 | 11:06 PM
  #40
dmoffitt's Avatar
dmoffitt
you're not kidding re: tied in to the body. can't wait to see the finished product!
