Nissan's at RedLine Time Attack
Old Jun 2, 2010 | 11:37 AM
  #41
Zazz93's Avatar
Zazz93
I think the setup would work better with ducting as well. Not to say the 370 and 350 are ultra close in brake setup but the C&D brake fiasco was nailed down to cooling (or lack of). After they changed the pads and fluid they got a moderate improvement but not enough. Considering Terra's got a good BBK the only thing I can see making a difference to keep him pushing through the session is the ducting. Afterall, the ducting is an easy mod and if that doesn't do the trick the pads and fluid are also available.
Old Jun 2, 2010 | 11:42 AM
  #42
Zazz93's Avatar
Zazz93
Hey Roger22 and Terrasmak, what kinda corner speeds are you carrying through 1 & 2? It looks like is easy to carry too much speed (especially without aero help).
Old Jun 2, 2010 | 11:59 AM
  #43
iStan's Avatar
iStan
ZR
high 80's low 90's , no cloud cover , track surface really freaking hot. Lap times cam down for everyone the second time attack session cause the wind picked up and cooled the track.
What was AIT and ECT running?
Oh and congrats on coming in 4th!
Old Jun 2, 2010 | 12:10 PM
  #44
roger22's Avatar
roger22
140mph with aero mods...
Old Jun 2, 2010 | 12:20 PM
  #45
03threefiftyz's Avatar
03threefiftyz
Terrasmark....what pads were you using?
Sorry for all the questions.....I am just curious.
Old Jun 2, 2010 | 12:44 PM
  #46
terrasmak's Avatar
I was showing about 137 on turn in, then bleed down a little speed thru the corner and back up to 132 for the braking point on turn 3. My car has a tucked bumper and stillen splitter for aero (yes its freaking hairy as hell thru those corners ) and i may get a Nismo V1 or V3 wing for the next event.
Brake pads, Wilwood Poly B that have already had 10 events on them and ATE Blue for fluid.
Old Jun 2, 2010 | 01:10 PM
  #47
roger22's Avatar
roger22
Wing helps a lot, I have run my car stock, with a Nismo rear wing and with Nismo rear wing and Stillen front splitter, Then added CF dual canards up front and then added the APR rear wing. Big difference at least 10 mph and car is stable with the downforce...
Old Jun 2, 2010 | 08:24 PM
  #48
terrasmak's Avatar
Well i'm contacting Fontana Nissan for the V1 wing, not much downforce or stability but it fits the rules of my class. My team mate (Focus SVT) started tracking down the ducting parts, were doing ducting on both cars.
Next event is at Willow, not many heavy braking areas but the aero will definatly help. I'm also going to try get my motordyne XYZ pipe back in, that should help me a bit with power for the next event.
Few camber adjustments, ducting, aero, and a general tune up. I will be ready to rock at Willow Springs.
Old Jun 2, 2010 | 08:37 PM
  #49
Zazz93's Avatar
Zazz93
I'm hoping to get my car rebuilt in time for Willow.
Old Jun 4, 2010 | 06:51 PM
  #50
Zazz93's Avatar
Zazz93
Terrasmak, heres a look at what a guy in a S2K did for brake cooling...http://www.robrobinette.com/S2000BrakeDucts.htm
Old Jun 4, 2010 | 09:35 PM
  #51
terrasmak's Avatar
Terrasmak, heres a look at what a guy in a S2K for brake cooling...http://www.robrobinette.com/S2000BrakeDucts.htm
Sweet, now do i run 2inch or 3inch ducts. Time to measure what kind of clearance i have.
Old Jun 5, 2010 | 08:59 AM
  #52
Zazz93's Avatar
Zazz93
Note the Fontana Z runs two 3 inch ducts per side. Here's a link to couple of CFD images of brake cooling. http://www.metacomptech.com/cfd++/cf...ke_cooling.htm
Old Jun 8, 2010 | 10:53 AM
  #53
terrasmak's Avatar
<object width="400" height="300" ><param name="allowfullscreen" value="true" /><param name="allowscriptaccess" value="always" /><param name="movie" value="http://www.facebook.com/v/1363595095966" /><embed src="http://www.facebook.com/v/1363595095966" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="400" height="300"></embed></object>
Vid from my run, batteries died mid run, the other clips were from trying to get the camera to work, my friend just threw all the clips together in one vid. I had the camera mounter upsidedown, and thought i had the setting proper to record, so we had to do some vid flipping.
Old Jun 8, 2010 | 11:01 AM
  #54
BornSlippyZ's Avatar
BornSlippyZ
Nice vid Terrasmak!
Old Sep 20, 2010 | 09:05 AM
  #55
Zazz93's Avatar
Zazz93
Anyone make it out to RTA Spring Mountian?
Old Sep 20, 2010 | 09:06 AM
  #56
Zazz93's Avatar
Zazz93
Congrats Terrasmak, I saw that third in class finish/time.
Old Sep 20, 2010 | 11:19 AM
  #57
terrasmak's Avatar
Thank you, I shaved 2.8 seconds off my personal best at that track to do it.
Old Sep 20, 2010 | 11:29 AM
  #58
Zazz93's Avatar
Zazz93
How did Roger's car fare? I read about a Friday or Saturday visit into the tires.
Old Sep 20, 2010 | 12:07 PM
  #59
terrasmak's Avatar
He snapped another from hub=NO BRAKES. Hit the tires after a long rally session thru a 100+ yards of sand trap. The car is being torn apart at http://www.paladinadvancedauto.com/ as I type. New door, front fender, hood and windshield and it will be at the next event. Sucks, we just put a new front end on the car from a hit n run in front of his house 7 months ago.
Old Sep 20, 2010 | 01:12 PM
  #60
Zazz93's Avatar
Zazz93
Doh... No brakes, never a good thing. Cool to see him ok and the car not too badly damaged.
