Help with Wheel/Tire size!
Help with wheel sizes Please.
Want to make my 03 Z a dedicated track car. I have good experience and
run in the upper run groups in DE's. I/m considering Enkei PFO1's
8.5 245/35/18 F and 9.5 275/18/40 R. offset's ? To be run on R6 Hoosiers.
Is that wide enough? I need them to clear 14" Stoptech's.
I know there is some who run square vs staggered. I need some advise from people that run a dedicated track setups.
Thanks
Thanks
For Hoosiers you can run 285's up front on 9.5 X 18 with ET 20-24 and for rear run 295 Hoosiers on 18X9.5-10.5 on ET 18-25 also. You can also run
295's on all four for a square setup. depends on HP and driving style. 295's all four is very neutral with power on oversteer. For high HP you can run 315 rear on 10.5-11 with rolled fenders but widest up front would be the 295's.
Thanks
Thanks
Don't go by their website as I have run the 285 and 295 on 9.5 width no problems on all four corners. I have not run 315's myself but others have run 315 Toyo 888's on 10.5's successfully...
Toyo approves the 315 tire on a 10.5" wheel, likely because it's only 0.1" wider than their 305: http://toyotires.com/tire/pattern/proxes-r888
Hoosier does not: http://www.hoosiertire.com/
Believe me, I'd love to get someone at Hoosier to say that the 315 is ok and better (i.e. will be faster) than their 285 or 295 on my 10.5" wheels, as I'd run them myself.
Agreed!
25 pics of 285/30/18s on 18x10 RPF1 wheels: http://gotbluemilk.com/web100225/219/index.html
4 x 18x10 +38 with 285/30 tires. 10mm spacer in the front and 15mm spacers in the rear.
Another pic with the 285/30/18s all around coming out of the corkscrew at Laguna Seca.
285/30 fronts and 295/30 rears on them are ok, too, and I'm confident the 295 will fit up front with no problem as well.
