Removable Numbers?
Old Mar 26, 2013 | 01:11 PM
DmanG281's Avatar
DmanG281
Default Removable Numbers?
So my magnetic numbers from autocrossing have seen better days. Also since I plan on attending more track days and any sustained speed over 50 tends to send magnetic numbers flying I am on the hook for some new numbers.
Anyone have a line on some removable numbering?
I'd like to just get a decal made but the car will still see street service for the short term until I buy a truck.
Thanks,
D
Old Mar 26, 2013 | 02:44 PM
SQuaLZ's Avatar
SQuaLZ
Also interested. In for some answers.
Old Mar 26, 2013 | 03:16 PM
SR71's Avatar
SR71
Lead Super Moderator
Make a outline/stencil of the number(s) you use and spray plasti-dip to fill in. Works great and its easy to remove.
Old Mar 26, 2013 | 03:39 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
My magnetic numbers stay on regardless of where or how fast I'm driving. I got mine from a local member years ago and I can't remember where he got them, unfortunately.
You can also look into those vinyl/film looking numbers that you apply onto a wet surface with a squeegee.
Old Mar 26, 2013 | 04:14 PM
SmoothZ's Avatar
SmoothZ
Senior Super Moderator
http://www.mnautox.com/forums/showth...racing+numbers
MAKE YOUR OWN NUMBERS
The ones I make myself are actually more visible than many of the ones you
can buy, and will work on any color car.
I use the heavy-duty white magnetic background and black 3M ControlTac (NOT SCOTCHCAL!) film.
I print on my printer at home in Helvetica Bold or similar simple sanserif
font and use the outline style to save on ink. Roughly cut out numbers,
leaving a half-inch or so of paper outside the outline. Punch holes in
paper numbers with a paper punch.
(Rocky Mountain Solo has a page where you can print from a PDF. Go to
http://www.rmsolo.org/makenumbers.html This will use up more toner than
outline numbers, though.)
Lay out the rough-cut numbers on black film. Put a square of scotch tape
over each punched hole.
Cut out the numbers with scissors, following the lines on the paper.
Peel off the paper outline.
The 3M ControlTac film allows pretty easy repositioning until you really
press on it. Even months later, I have found that it can be removed with
patience and fingernails. Putting it in the freezer first helps.
Using a white background insures that the numbers will work on any color
car. Studies have shown that monochrome reflection contrast is the only
thing that really counts. Color-contrast is essentially worthless. The best
contrast is, predictably, black and white.
Large magnetic pieces stay on the car better than numbers cut out of
magnetic material. I have put large magnetics on cars bridging over rubber
trim, and they still stayed on the car at autocross speeds.
Old Mar 26, 2013 | 05:22 PM
DmanG281's Avatar
DmanG281
Thanks for the suggestions. Just remembered that the Corvette guys use the static-cling vinyl film. Going that route.
Old Mar 26, 2013 | 06:37 PM
nkohler's Avatar
nkohler
I had mine made at a sign shop for a pretty reasonable price for when I used to autocross. They are basically one big magnet. I have had them for around 7 years or so and they held up to 125mph and in pretty cold weather this weekend.
Old Mar 26, 2013 | 07:02 PM
terrasmak's Avatar
I just sealed the leading edge of my magnets with tape
Old Mar 27, 2013 | 04:48 AM
SamC's Avatar
SamC
http://www.izoomgraphics.com/
I have used these for 3 years with no problems, autocross and track. The outlined autocross set looks great.
Old Mar 27, 2013 | 06:57 AM
SQuaLZ's Avatar
SQuaLZ
Great info just ordered mine!!
Rolling with number 350 for this year
Old Mar 27, 2013 | 04:03 PM
SmoothZ's Avatar
SmoothZ
I had those numbers for one autox season.
Old Mar 28, 2013 | 05:25 PM
2000atlanticgt's Avatar
2000atlanticgt
SamC, magnetic set or reusable vinyl? I am thinking about trying the reusable vinyl.
Old Mar 28, 2013 | 07:45 PM
SamC's Avatar
SamC
I use magnetic
Old Mar 28, 2013 | 08:02 PM
omgitsweasel's Avatar
omgitsweasel
both of my suggestions involve business advertising magnets.
one is to just get one used and spray paint your own numbers.
second is to just have the magnetic sign made with your numbers on it.
those signs arent going anywhere. I personally witnessed a video production company's camera car that had one on either door, up to about 145 mph.
as with any magnets seeing high speed, always tape the leading edges like terrasmak mentioned.
Old Mar 30, 2013 | 08:35 AM
91rs13's Avatar
91rs13
You could also check into these guys for reusable vinyl numbers. I have had good luck with them over the years.
http://www.soloperformance.com/Reusa...nyl_c_431.html
Old Apr 1, 2013 | 11:26 AM
SQuaLZ's Avatar
SQuaLZ
Got my numbers on Saturday from izoom. Got the cheapest ones but still love them. They feel like great quality.
Old Apr 2, 2013 | 06:00 AM
DmanG281's Avatar
DmanG281
Did you get he removable vinyl or magnetic?
Old Apr 2, 2013 | 06:07 AM
SQuaLZ's Avatar
SQuaLZ
Magnetic.
Old Apr 2, 2013 | 01:31 PM
SamC's Avatar
SamC
You could paint them silver and they would look great....not that they don't look good as is. Just throwing out some ideas.
Old Apr 2, 2013 | 03:14 PM
3hree5ive0ero
Retired Admin
White > Silver, especially when it comes to lettering (plus, it'll be more visible and on more cars).
sales@czp
Sep 23, 2019 03:30 PM
Depravity
Oct 1, 2015 04:49 PM
