DIY- Titek Air Duct
Old Jan 12, 2010 | 01:20 AM
  #61
maXmood's Avatar
maXmood
Under Boost!
thanks for the write-up...
does Titek comes with rivet washers as well? i mean, how the rivets are suppose to hold long enough?
Old Jan 14, 2010 | 08:57 AM
  #62
ZS14RR's Avatar
ZS14RR
Just pop rivets. thats all you need. You predrill a hole and jam in the pop rivet then you you start squeezing the handle and it POPS.
Old Feb 10, 2010 | 03:41 AM
  #63
maXmood's Avatar
maXmood
Under Boost!
i've installed mine last night.. it was a pain with the template that comes with Titek..
anyways, after punching the rivets in, now one has come out half way!?!
is there any way i can remove it without destroying the duct?
and i still think it requires more cutting to make it sit flush.. is that doable? or am i going to need a new bumper :S
Old Feb 10, 2010 | 06:22 AM
  #64
ZS14RR's Avatar
ZS14RR
just cut it with a dike plyer and put another pop rivet in.
yea the template they provide is garbage.
cut away i did.
Old Feb 10, 2010 | 08:08 AM
  #65
maXmood's Avatar
maXmood
Under Boost!
^won't reach.. the gap is very small between the duct and the bumper (where it shows the rivet) ..
Old Feb 10, 2010 | 09:16 AM
  #66
Dan Garcia's Avatar
Dan Garcia
grind off the top of the rivet with a dremel and then push it in and it will fall through, the top portion of the rivet will fall off, done it lots of times. when you grind off the top of the rivet just make sure you don't damage the carbon fiber.
Old Feb 10, 2010 | 09:34 AM
  #67
maXmood's Avatar
maXmood
Under Boost!
uhhh..... i was able to pull off the duct and cut the rivets with a dike plier.. managed to take off all 4 rivets. since i cut alot of the bumper to try and fit the duct, i didn't have much room to play with it much, but i had a go at the foam piece and trimmed it a bit. the duct now sits almost flush (way better than before) but still has a small gap.
satisfied with the end result.
thanks for the suggestions
Old Nov 17, 2010 | 03:51 PM
  #68
Token_Z33's Avatar
Token_Z33
Does anyone know were i can get just the stincle for the air duct to make an accurate cut? or at least the dimensions so i can make my own
Old Feb 11, 2011 | 11:55 AM
  #69
ZS14RR's Avatar
ZS14RR
the stencil is about a 1/4" to small all the way around so it worthless.
Old Dec 27, 2012 | 07:54 PM
  #70
andypants101's Avatar
andypants101
Originally Posted by ekim1
great DIY. that must have been painful cutting a hole in the Z. haha
Haha I completely agree... and what about using a dremel tool?
Old Jan 18, 2013 | 06:56 AM
  #71
LtAllen22's Avatar
LtAllen22
Quick question, my TiTek came with 3m double sided tape.. should I use it on the edges of the duct or just rivet it in and call it quits...
Old Aug 31, 2014 | 08:07 AM
  #72
NissanZFanatic's Avatar
NissanZFanatic
Default Nissan 350Z Air Duct
I know this is a old thread but here's a template for the air duct! Follow the link.
https://my350z.com/forum/attachment.php?attachmentid=136014
350Z_Al
Oct 29, 2020 07:44 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
