DIY: Rear Strutbar Cover Removal & Paint
Old Aug 4, 2012 | 11:47 PM
SnaggleToof's Avatar
SnaggleToof
Did mine today, but I used CF vinyl instead of paint...
Old Sep 27, 2012 | 09:29 PM
Azzerare's Avatar
Azzerare
Great write up, thanks!
Sub'd!
Originally Posted by Z7757
Did mine red and black aswell. was a pain to tape off the little black squares, but well worth it
worth it indeed, that looks awesome!
Originally Posted by DViper0020
I did mine a few weeks ago when I painted some of my interior trim. The previous owners of my Z didn't care about scraping the strut bar, because that thing looked awful. The chrome plating on the Z in the center of the strut bar was wrinkling a bit too, so I figured I should do something about it. In the pics the bar looks white, but it's silver. It actually isn't as reflective as the stock silver that was on the strut bar either, which I like.
Killer. I love it
That's a really cool look- how difficult was the wrap to work with?
What cage setup is that?
Old Mar 25, 2013 | 03:20 PM
frocker93's Avatar
frocker93
Thought I'd share mine that I finally got around to doing.
Attached Thumbnails DIY: Rear Strutbar Cover Removal & Paint-image.jpeg
Old May 11, 2013 | 08:35 PM
skrubnagrom's Avatar
skrubnagrom
How do you remover the circles around the AC ***** and the circle aroudn the shifter to paint those?
Old May 14, 2013 | 08:40 AM
skrubnagrom
finished mine:
Old Jun 1, 2013 | 07:15 AM
Noor93y's Avatar
Noor93y
Originally Posted by skrubnagrom
finished mine:
Looks great man
Old Jun 27, 2013 | 10:50 PM
HeLLSaTaN's Avatar
HeLLSaTaN
any chance anybody know what part # part C in this pic is?
I ended up snapping a clip on mine and need to get a new one now
I was a little too forceful i guess.
Old Jul 1, 2013 | 09:46 AM
Tearik's Avatar
Tearik
Can you do the same process to the emblem? Mine is sun wrinkled and what not
Old Jul 18, 2013 | 08:18 AM
That z's Avatar
That z
Looks Awesome! this is the exact same color scheme I plan to use on mine!
Old Aug 6, 2013 | 07:48 PM
puck77's Avatar
puck77
I did mine with something a little different. I used spray on bedliner. You guys will probably flame me for that but I think it looks really good. The texture is pretty subtle and matches the other interior plastics a bit better than gloss paint in my opinion. My pics aren't the greatest but here it is.
Old Aug 31, 2013 | 05:37 PM
ReaBeltran's Avatar
ReaBeltran
Painted mine via this DIY tutorial. Thanks for the write up was very helpful:
DIY: Rear Strutbar Cover Removal & Paint-wmox2kh.jpg
Old Sep 5, 2013 | 05:19 PM
nc crucial's Avatar
nc crucial
heres how i did mine, also going with the black/red scheme. i did a couple pieces under the hood but idk how i feel about it. lemme know what you guys think.
what its in incase anyone was wondering what the rest of the scheme looks like lol
Old Sep 5, 2013 | 07:21 PM
dcains's Avatar
dcains
Of the various pics posted in this thread, this is the one I like the best. Different, but subtle, which is how I prefer mods to be. Mine is being hydrodipped in a CF pattern to match the interior pieces I had done up front.
Old Sep 10, 2013 | 10:20 PM
dcains's Avatar
dcains
The emblem is actually covered with a thin metal coating. Too tough to sand off, but if you're careful you can chip/peel it away with a sharp blade. If you manage to do that without beating up the plastic underneath, you can repaint it as you please. I used a VW silver touch-up spay paint, which is fairly close to the original color and luster. Spray on maybe 6 or 8 thin coats and wet-sand it to get a smooth, glossy finish.
Old Sep 10, 2013 | 10:26 PM
dcains's Avatar
dcains
If you give a sharp tug backwards on the shifter surround panel, it will come loose from the center console. Then you can use vise grips, if needed, to hold the shift lever from twisting and unscrew the shift ****. Next, there is a ribbon cable connecting the A/C controls you need to unlip, and once that's done you can pull the shifter surround panel free. The A/C controls are held in place by a few screws, as is the metal trim around the shift boot.
Old Sep 11, 2013 | 05:10 AM
tking180's Avatar
tking180
What did you use to paint it under the hood? any specific paint?
Old Sep 11, 2013 | 05:54 PM
nc crucial's Avatar
nc crucial
nothing overly specific. just the krylon plastic paint from walmart. just make sure theyre stupid clean before you paint them
Old Sep 13, 2013 | 11:09 AM
  #38
Sheasta's Avatar
Sheasta
Had some cf wrap left over so did this: Name:  20130913_144914.jpg
Old Sep 17, 2013 | 09:40 AM
  #39
dcains's Avatar
dcains
Finally got my hydrodipping done, not yet installed, but check out the pics:
Old Oct 2, 2013 | 11:01 PM
  #40
That z's Avatar
That z
Default Mine
Thought Id put up the finished pic of mine since this DIY helped me out alot with removing all the panels and then reassembling them
Attached Thumbnails DIY: Rear Strutbar Cover Removal & Paint-img_2125.jpg
