380RS pedal install
Old May 16, 2012 | 06:12 PM
F2CMaDMaXX's Avatar
F2CMaDMaXX
Default 380RS pedal install
This little upgrade has been sitting around for ages, i wanted to clean out the footwell before i took photos. That didn't happen, but here i present the 380RS pedal upgrade, with some basic direction to perform this nice basic mod
Nissan 380RS accelerator pedal, a special edition of the 350Z made by Nissan in Japan.
Here is the stock pedal setup.
You need to insert a flat blade screw driver here, then twist gently.
That should remove the clip, don't worry if it flies off, just make sure you find it.
The pedal should now hinge downwards, just slide it off to the side to remove the pedal from the shaft.
This is the clip from the back, it just fastens around the shaft and clips to the back of the pedal.
Turn over the old pedal and locate this plastic insert, we need this also.
Insert a the flat blade screwdriver here and twist again.
You'll be left with this piece which has a hole in one end for the accelerator shaft.
Here is the stock pedal on the left with the new RS380 pedal on the right.
And again, turned upside down.
Insert the plastic piece with the hole facing outwards.
And simply slot back over the accelerator shaft again and flip the pedal back up.
Squeeze the clip back at the top. Make sure it clicks on tight.
Old May 16, 2012 | 06:47 PM
PikesPeakZ's Avatar
PikesPeakZ
Easy enough thanks I'll grab one from Z1
Old May 16, 2012 | 06:58 PM
F2CMaDMaXX's Avatar
F2CMaDMaXX
Yup, very easy, nice upgrade and these pedals are under $30 now.
Flo-ridaZ33's Avatar
Flo-ridaZ33
good write up... I love mine.
Old May 16, 2012 | 07:18 PM
PikesPeakZ's Avatar
PikesPeakZ
Where are they under $30?
Old May 16, 2012 | 07:25 PM
Duckeee's Avatar
Duckeee
Where are they under 30...
Old May 16, 2012 | 07:31 PM
PikesPeakZ's Avatar
PikesPeakZ
LOL, Duckeee you keeping your ride brother?
http://www.ebay.com/itm/Nissan-JDM-3...#ht_1603wt_907
Old May 16, 2012 | 07:32 PM
F2CMaDMaXX's Avatar
F2CMaDMaXX
Sorry, it about $36 with shipping.
http://www.ebay.com/itm/JDM-INFINITI...ht_1877wt_1163
Old May 16, 2012 | 08:16 PM
KingBaby's Avatar
KingBaby
Hardest Setting
Not needed but nice you made one
Old May 16, 2012 | 08:25 PM
F2CMaDMaXX's Avatar
F2CMaDMaXX
True, but some people really aren't sure without seeing something like this, still, it's nice to document the things i do to my car.
Old May 16, 2012 | 08:32 PM
ImWeeZzel's Avatar
ImWeeZzel
Nice write up
Old May 16, 2012 | 08:44 PM
jv350z's Avatar
jv350z
great!
Old May 16, 2012 | 09:52 PM
EmpireDude's Avatar
EmpireDude
Vendor - Former Vendor
love mine!
Old May 17, 2012 | 08:35 AM
Duckeee's Avatar
Duckeee
yeah im keeping it. YEAHHH
getting art pipes and uprev soon
Old May 17, 2012 | 09:10 AM
PikesPeakZ's Avatar
PikesPeakZ
Glad to hear it. Would be sad to see another well done Z go only to have someone swap the Works for Varrs. LMAO
Old May 17, 2012 | 09:20 AM
User 42426's Avatar
User 42426
i know its probably just for looks, but did you feel any difference at all on the foot? More comfortable/uncomfortable. Normally I would buy this just because it looks better, but wondering if there is anything more to it lol thanks
Old May 17, 2012 | 09:58 AM
F2CMaDMaXX's Avatar
F2CMaDMaXX
Heh, it's not for looks, but it does look good, like the stock pedals.
It's to more easily enable heal'n toeing when downshifting. The stock pedal placement does not easily allow this method, this brings the edge of the pedal closer to help.
As for feel, other than the above added assistance, it feels just like the stock pedal.
Old May 17, 2012 | 10:31 AM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
Anyone know how easy it is to get the rubber out of the stock pedals? It'd be nice if the clutch and brake matched the gas pedal.
Old May 17, 2012 | 01:44 PM
terrasmak's Avatar
Looks good, simple to install, and makes heal toe downshifting easier. I love mine. Fontana Nissan probably still has a couple in stock
Old May 17, 2012 | 02:10 PM
dkmesa350z's Avatar
dkmesa350z
Can't believe you made a writeup for this on a z already equipped with aluminum pedals lol. My swap took 13 seconds including 9 seconds to figure out the clip holding the pedal on.
