Body Interior Seats, shift knobs, etc.
Stack Pro Control Multi Color Gauges - Accurate, Affordable, and Tons of Features!
Old Dec 7, 2010 | 05:49 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Default Stack Pro Control Multi Color Gauges - Accurate, Affordable, and Tons of Features!
Stack is one of the oldest, and most respected names in aftermarket instrumentation. Founded in the UK, and distributed worldwide, Stack gauges can be found in all forms of motorsport.
Stack’s Pro-Control range of Professional Stepper Motor Analogue Gauges brings total control and driver awareness of critical engine functions. The gauges are user configurable with Maximum/Minimum alarms which can be set with one of seven different colours to indicate status.
No Control Unit Needed - everything is controlled on each gauge!!
The Pro-Control series has all of the features of the Professional Analogue Gauges plus:
Peak Values recall
Configurable Max and Min full dial alarm warnings
Temperature gauges with built-in “fan controller”
Configurable Pro-Control output for activating accessories eg. fans, pumps, etc (requires relay)
Pressure gauges with built-in “pump controller”
0-5 Volt analogue output for data logger or ECU
Configurable backlight colour
Black dialface when powered off
Available in metric or imperial (US) measurement
Includes all required wiring and sensors (except fuel level gauge and battery voltage gauge)
Accurate and reliable, all gauges (except the digital Air/Fuel gauge) feature LED through-the-dial and needle backlighting and come complete with wiring harness and associated sensor (except for fuel level gauges).
User-configurable minimum and maximum alarms can be set, with one of seven different colours assigned to each.
As soon as an alarm level is exceeded, the full dialface changes colour. If the level exceeds the alarm by more than 10%, the dialface flashes rapidly to further alert the driver.
With a choice of 7 user-selectable LED backlighting colours ( red, green, yellow, blue, purple, turquoise and white) the user can choose the optimum colour for maximum visibility and readability of the gauge, day and night.
All are 52mm, and available for purchase in either metric or imperial (US) measurements!
Available in the following:
Oil Pressure
Oil Temperature
Fuel Pressure
Water Temperature
Boost (35 psi)
EGT
Fuel Level
Battery Voltage
Prices range between $182 per gauge and $230 per gauge. Package deals available when purchasing 3 or more! We also have various gauge pods in stock too too, from single to multigauge mounting.
Stack also has thoughtfully released a 52mm wideband Air Fuel Gauge as well! Includes Bosch wideband sensor, and features an integrated digital display. Available in your choice of white face background or black face background.
Features:
User-selectable Air/Fuel or Lambda real time display
Includes Bosch sensor
Programmable Alarm warns of dangerous lean condition
Peak Recall of leanest value during last run
Suitable for all fuel types with AFR from 6:1 to 20:1
0-4 Volt Data Logger or ECU output
The wideband is priced at $340.00
Package it with any of the above gauges, pod for a total package deal!
To spec out your gauge package and order, just give us a shout!
Old Dec 30, 2010 | 08:42 AM
Z1 Performance
Former Sponsor
bump!
Old Jan 12, 2011 | 06:21 AM
Z1 Performance
Former Sponsor
up!!!!
Old Jan 23, 2011 | 06:19 AM
Z1 Performance
Former Sponsor
Weekend bump
Old Feb 2, 2011 | 12:13 PM
Z1 Performance
Former Sponsor
ttt
Old Feb 27, 2011 | 02:37 PM
goldenboi1's Avatar
goldenboi1
Default problems with these guys
Just wondering if anyone has tried to order anything from these guys lately and are having problems with payments or receiving parts. Whats going on guys?
sales@czp
Sep 23, 2019 03:30 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
