Body Interior Seats, shift knobs, etc.
STACK now available at MVP Motorsports!!
Old Jul 12, 2011 | 03:22 PM
Chops@MVP's Avatar
Chops@MVP
Default STACK now available at MVP Motorsports!!
Multi-Function Dash Display
Stack 52mm Auxiliary Gauges:
Pro-Control Stepper Motor Analogue
* Peak “tell-tale” Memory - Max temps, Min pressures
* Configurable max and min full dial alarm warnings
* Configurable Pro-Control output for activating accessories eg. fans, pumps, etc (requires relay)
* Temperature gauges with built-in “fan controller”
* Pressure gauges with built-in “pump controller”
* 0-5 Volt analogue output for data logger or ECU (except EGT and Fuel Level gauges)
* Configurable backlight colour
* Black dialface when powered off
Available Readouts:
ST3501 Oil Pressure 0-7 bar (M10x1)
ST3502 Oil Pressure 0-100PSI (1/8NPT)
ST3503 Fuel Pressure 0-1 Bar (M10x1)
ST3504 Fuel Pressure 0-15 PSI (1/8NPT)
ST3505 Fuel Pressure 0-7 Bar (M10x1)
ST3506 Fuel Pressure 0-100 PSI (1/8NPT)
ST3507 Water Temperature 40-120°C (1/8NPT)
ST3508 Water Temperature 100-260°F (1/8NPT)
ST3509 Oil Temperature 40-140°C (1/8NPT)
ST3510 Oil Temperature 140-280°F (1/8NPT)
ST3511 Boost Pressure -1.0 to +2.0 Bar (Uni)
ST3512 Boost Pressure -30inHg to +30 PSI (Universal T-Fitting)
ST3513 Exhaust Gas Temp. 0-1100°C (1/8NPT)
ST3514 Exhaust Gas Temp. 0-2000°F (1/8NPT)
ST3515 Fuel Level (programmable)
ST3516 Battery Voltage 8-18 V
Wideband Air Fuel Gauges
Dual digital and radial LED displays provide accurate real-time readout of either air/fuel ratio or lambda (user-selectable). A 0-4Volt analogue output can be connected to a data-logger or to an ECU to provide real-time closed-loop feedback for improved mapping. Supplied complete with wiring harness and includes Bosch sensor.
* User-selectable Air/Fuel or Lambda real time display
* Programmable Alarm warns of dangerous lean condition
* Peak Recall of leanest value during last run
* Suitable for all fuel types with AFR from 6:1 to 20:1 (not recommended for leaded fuel)
* 0-4 Volt Data Logger or ECU output
These are just a few of the great products offered by Stack Ltd. Click here for a full listing of their products:
http://www.stackltd.com/mshome.html
PM OR POST UP TO GET YOUR MY350Z PRICING!!
Regards,
Robert
SharX59
Sep 30, 2015 10:54 AM
