Body Interior Seats, shift knobs, etc.
DEFI 60MM Racer Series Gauges IN STOCK in OUR WAREHOUSE! NO DROP SHIP!!!!!
Old Feb 8, 2012 | 03:23 PM
rallysportdirect's Avatar
rallysportdirect
Vendor - Former Vendor
Default DEFI 60MM Racer Series Gauges IN STOCK in OUR WAREHOUSE! NO DROP SHIP!!!!!
The Defi Racer Series Gauges are quick-responsive and high-accurate analog gauges. Boost, pressure, temperature, exhaust temperature, and volt gauges are available. They are 60mm in size and the lighting is available in blue, red or white.
A Stepping motor provides smooth operation. The Racer gauges are illuminated using high-brightness LEDs. Self-diagnostics function monitors both sensor disconnection and short-circuiting during the startup sequence.
The Face features a full 270 degrees sweep dial provides ultimate visibility. The Defi Racer Gauge does not require the Defi-Link Control Unit II for use, and cannot be used in conjunction with it. The red triangle of the regular position bezel can be used as a warning indicator and others. A mounting bracket and instrument case is provided with the gauge.
Imperial or Metric
Red, White, or Blue
Boost, E.G.T. (Exhaust Gas Temp), Pressure, Temperature, Voltage
$214.20
Boost/Turbo In Metric or Imperial
Pressure in Metric and Imperial
For Oil Pressure of Fuel Pressure
$248.40
Temp in Metric and Imperial
For Oil Temp, or Water Temp
$169.20
Exhaust Gas Temp in Metric and Imperial
$248.40
Voltage
$135.90
RICK APPROVED AND IN STOCK!
Also don’t forget all orders over $200.00 get free shipping in the lower 48 states!
Old Nov 15, 2012 | 10:55 AM
rallysportdirect
Defi's in stock ready to ship! We always keep a big selection in stock and ready to go to you so no long waits on getting what you need and want If you have any questions just let us know.
Thanks,
Dallin
chief3630
Feb 29, 2016 02:54 PM
bcoffee20
Nov 19, 2015 06:39 PM
EnjukuRacing
Misc.
Sep 23, 2015 07:27 AM
abarclay
Wheels Tires
Sep 21, 2015 04:51 AM
Calinismo350z
Sep 14, 2015 04:04 PM
