DIY: Lower Control Arm and Radius Arm Removal/Install
Old Jan 31, 2012 | 01:22 PM
L-Fab's Avatar
L-Fab
Default DIY: Lower Control Arm and Radius Arm Removal/Install
For anyone interested in swapping out their Front Suspension Bushings, below are the instructions for removing and reinstalling the Lower Control Arm [Transverse link] and the Radius Arm [Compression Rod].
LOWER CONTROL ARM [TRANSVERSE LINK]
REMOVAL
1. Remove tire
2. Remove undercover
3. Remove mounting nut and washer on lower portion of swaybar endlink
4. Remove mounting nut between transverse link and shock absorber on lower position.
5. Remove mounting nut between transverse link and steering knuckle
6. Remove transverse link from steering knuckle
7. Remove transverse link from vehicle.
INSTALL
1. Reverse of above
2. Tighten all nuts / bolts to specified torque
RADIUS ARM [COMPRESSION ROD]
REMOVAL
1. Remove tire
3. Remove front cross bar from vehicle
4. Remove cotter pin of compression rod ball joint, and loosen nut.
5. Use a ball joint remover (suitable tool) to remove compression rod from steering knuckle. Be careful not to damage ball joint boot.
CAUTION:
Tighten temporarily mounting nut to prevent damage to threads and to prevent ball joint remover (suitable tool) from coming off.
6. Remove compression rod from vehicle.
INSTALL
1. Reverse of above
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
