Question on JIC FLT-A2 and JIC Camber kit
Old Mar 30, 2005 | 12:14 PM
aychoy's Avatar
aychoy
Default Question on JIC FLT-A2 and JIC Camber kit
Hi,
Is there anyone running JIC Camber kit and JIC FLT-A2? I want to know how much adjustment can you make with the camer kit. My shop told me that JIC kit will max out (not short enough) and can only lower the camber to around 2.7degree. The car is lowered about 1 - 1.5". He also said he tried Stillen camber and end up with similar problem. Can't adjust it back to around stock setting.
If someone has a the above setup, please post you camber angle and also want how much you've lowered your car.
Many thanks!!
Old Mar 30, 2005 | 12:54 PM
J Ritt's Avatar
J Ritt
I'm using that combo. I ran the car ranging from 1" lower than stock to 3" lower than stock. Rear camber was set at roughly 2 degrees negative in both instances. I run a fairly aggressive setup geared towards track performance more than street, but I these pieces do have a wide range of adjustment, and you should be able to find a good setting with them.
issyz
Jul 2, 2017 03:04 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
