Too much Negative Camber?
Old May 7, 2005 | 06:15 PM
laswyguy's Avatar
laswyguy
Default Too much Negative Camber?
I went to the dealer and got an alignment.
-1.8% front
-2.8% rear
Thats the most they could get it in spec. Am I cool? Car handles bad *** but is this gonna kill my tires?
Old May 7, 2005 | 07:09 PM
ssc's Avatar
ssc
i would consider getting some camber kits..btw, how much are u lowered?
Old May 7, 2005 | 07:24 PM
del105's Avatar
del105
15 f125
your tires will be fine. most tire wear is caused by toe not camber.
The front seems good from a handling perspective. There is a little to much camber in the rear though.
Old May 7, 2005 | 08:04 PM
laswyguy's Avatar
laswyguy
id say 2.5 inches in the front 3 inches in the back. its pretty slammed... but it handles craaaaazy.
Old May 7, 2005 | 09:37 PM
mrbader's Avatar
mrbader
What are you lowered with? Cut Springs or Coilovers?
Old May 8, 2005 | 11:51 AM
laswyguy's Avatar
laswyguy
JIC FLT2as... simply awesome is all I can say.
Old May 8, 2005 | 04:41 PM
Gruppe-S's Avatar
Gruppe-S
Vendor - Former Vendor
Hi,
You prob want to consider getting a camber kit. It seems to me you are cambering a lil too much. I would recommend somewhere around -1.5 in the front and -1 in the rear. The last thing you want is to have you car ride on the edge of you expensive tires.
Its true that having a toe in will eat up the tires as well as having too much neg camber therefore I would get it fix asap if I were you. FYI...I just got some Cusco camber adjustable A-arm for the 350z....give me a call if you are interested.
HoBrahYouStink
Jun 24, 2016 10:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
