19" negative rear camber ? .. handling & advice
A question I think that has never been asked ...
1/ I am running 19" Volk TE37 8.5 inch front and 9.5 inch in the rear at spec +22 offeset .. with 245/35 and 275/35 tires .. I have no problem with the front, in my opinion, since a little negative camber is good for handling and there has been no major tire wear.
2/ The rear runs negative ... -- except for tire wear ...
Question ..
What is the problem with negative rear camber ??... Would this be good for handling ---or--- is it better handling to run the rears as close to factory specs / no camber by installing a rear camber arm from 350EVO or equivalent ?
Your opinions please ... thanks.
Question ..
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
