Eibach sway adjustment ?
Old Jul 28, 2005 | 07:22 AM
booger's Avatar
booger
Default Eibach sway adjustment ?
Just got some Eibach sways and would like to know how every one has thiers adjusted . Im running the stock springs right now . Thanks
Old Jul 28, 2005 | 08:21 AM
VQ35DECivic's Avatar
VQ35DECivic
Stock springs & shocks here; running stiff on front, medium in the rear. 41psi front, 38 rear.
The Z's very neutral at this setting. Easy to throttle steer at the limit, at least N/A anyhow.
Old Jul 15, 2006 | 07:34 AM
reptile718's Avatar
reptile718
I bought a set of Eibach sways used and installed them on the settings the previous owner had. Problem is instructions where not included so I don't know how they are set to which level of adjustment, don't know which hole does what for front or rear. Can anyone help out???? I have searched and come up with nothing. I would greatly appreciate it
Old Jul 15, 2006 | 09:11 AM
1nate7's Avatar
1nate7
The hole closest to the bar is the stiffest setting and the hole on the very end is the softest. Hope that made sense...
Old Jul 15, 2006 | 03:36 PM
reptile718's Avatar
reptile718
Thanks for the info, I have it set to soft/soft then. I also upgraded my springs to H. TECH's and shock/struts to the new revised 06 ones. It drives awesome but I wanted to improve my handling a little more. Which would be the best settings for something a little more aggressive but still able to use as a daily driver? Any opinions would help. I was thinking either hard/medium or soft/medium? Thanks again
Old Jul 15, 2006 | 04:05 PM
1nate7's Avatar
1nate7
I have the Hotchkis bars so keep that in mind. I ran med/med for a long time and was happy with it. I went to a non-staggered tire setup for track use so I set them to hard/med and just leave it there for daily driving as well. I tried soft/med once and the steering input felt a little sloppy to me. It doesn't take much adjustment to really change the feel. I would try med/med next and see how you like it.
Old Jul 15, 2006 | 04:10 PM
reptile718's Avatar
reptile718
hhhmmmm thing is I only have two levels of adjustment on the front which im guessing are soft and hard then three on the back? I will try soft/med first then swtich to hard/med and see which one I like best I guess
Old Jul 17, 2006 | 07:21 AM
Q45tech's Avatar
Q45tech
With adjustable sway bars the holes are just a ratio vs right angle arm length:
A 6" right angle whith holes at 6,5,4" ..........6/5=20% stiffer than the 6" hole;
6/4=50% stiffer than the both in 6" hole.
You can use different holes on different sides to gain finer adjustment:
5" + 4" = 35%.................6"+ 5"= 10% stiffer than both at 6"
Kind of important to KNOW the base stiffness in pounds per inch to determine stiffer than WHAT.
Hope concept is clear.
Whenever you increase front bar stiffness you increase understeer and the transfer load on the front tires in a turn making them handle more poorly [ratiowise].....the front should only be stiff enough to utilize the full stroke of the shock worst case......<3.5" of body roll.
Body roll is not bad [assumming adequate camber gain] --it tells the driver what's happening
Old Jul 17, 2006 | 07:39 PM
Gsedan35's Avatar
Gsedan35
You will not find much buy in to the theory of running oem front bar strengths in this community, way too many owners have proven otherwise.
Originally Posted by ULLLOSE
On camber challenged cars a bigger FSB can help reduce understeer as it controls camber loss. The Subi's and Mustangs also rotate better with a larger front bar. You can go to far but it does work on some strut cars with weak camber curves.
Old Jul 17, 2006 | 07:49 PM
reptile718's Avatar
reptile718
so basically what I want to know is there are two levels of adjustment on the front and three on the back which holes should use for best street performance and slightly more aggressive then stock, take into consideration that I have tein h. tech springs with the new revised 06 suspension and my sways are eibach BTW thanks!
dboyzalter
North East Marketplace
15
May 6, 2018 09:41 AM
hulkout
Apr 28, 2017 09:00 PM
