"Best" Camber/Toe Kit
Old Aug 7, 2005 | 04:46 PM
GoSooners's Avatar
GoSooners
Default "Best" Camber/Toe Kit
I'm about to replace my tires due to premature wear from incorrect camber and I need your opinions on a good camber kit that will adjust camber, and toe if available. Are there certain ones I should stay away from? Do they squeak? I know my alignment is maxed out, but I don't remember what the specs were. I'm dropped on RSR springs so that drop isn't too excessive so the kit I need shouldn't need a huge range of adjustability. I know SPC has a great one for the price but requires modification. Are there any that do NOT require modification and is just a bolt-on? I also autocross so I need something strong/stable. Thanks ahead!
Old Aug 7, 2005 | 05:03 PM
JDMFairlady21's Avatar
JDMFairlady21
i would say SPC camber arms and Toe bolts. I've been doing research for almost 6-7 months already and this combo seems the best for daily drivers and cost effective. for the front i would say 350evo or cusco.
Old Aug 7, 2005 | 05:59 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
He hit the nail right on the head for the fronts. The rear setup, you also can go with JIC and Stillen
Old Aug 7, 2005 | 06:00 PM
MIAPLAYA's Avatar
MIAPLAYA
The only CORRECT way to modify the toe is the SPC toe bolts. The other companies supposed "toe arms" will alter it but will through off your caster...
Old Aug 8, 2005 | 06:31 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
..have you seen this in person mia...because I have read this, and done several cars with toe arms and have not experienced this at all (my car included)
adam
Old Aug 8, 2005 | 06:47 PM
JDMFairlady21
yea thats something i really wanted to know for sure, wether its true or a myth i still dont know.
Old Aug 8, 2005 | 09:19 PM
dnguyent's Avatar
dnguyent
I'd have to agree with MIAPLAYA. I have the toe kit, but didn't need them because there was plenty of toe adjustment left for the mild 3/4" drop in the rear. I did, however, take apart the adjustment link, and learned how toe adjustments are made. I have no doubt that the toe bolts is the best route to go since it retains the same adjustment methodoligy as the OEM setup. Enlarging the existing slotted hole is not as bad as it's all made out to be.
Old Aug 9, 2005 | 04:49 PM
dank311's Avatar
dank311
I want to know this as well. What is the "best" way to adjust toe? On most other cars I see all have rods to make toe adjustments. Can anyone prove that the rods through off the caster?
Old Aug 9, 2005 | 05:05 PM
Z1 Performance
Former Sponsor
I can post my specs tomorrow....caster is within factory spec
Old Aug 10, 2005 | 06:27 PM
GoSooners's Avatar
GoSooners
Thanks for the suggestions guys!
Z1, looks like you have the "Cusco lateral/toe arms" one your car but you don't have it on your website. Do you have these in stock? How much do they run for? And is this the set you are referring to that works like the SPC that adjusts like OEM?
Old Aug 10, 2005 | 07:36 PM
Z1 Performance
Former Sponsor
I have the prototypes - won't be released till next year
EnjukuRacing
Sep 30, 2015 06:55 AM
