Facory Alignmet Specs For Rear Camber
Dec 1, 2005 | 07:26 PM
What's the factory camber range for the rear wheels?
Respect
JET
Dec 1, 2005 | 08:10 PM
Off the top of my head, I could be wrong, -.9 through -1.3
Dec 3, 2005 | 03:05 PM
Quote:
Respect
JET
Camber is -1.1 to -2.1 degrees
Toe is .01 to .09 degress
Dec 3, 2005 | 04:40 PM
Wow -2.2 camber in the rear is in spec? That is crazy, well Im barely in spec then -1.9 out back.
Feb 15, 2006 | 10:29 AM
Does anyone know the optimal camber/toe setting for the rear after only a 0.75" drop?
On my first Z it was aligned at -1.9 and -2.0 in the rear. I'd like the camber to be closer to -1.5 this time.
I know that the toe can really chew up some tires as well. But I don't want to sacrifice handling for everyday driving. Maybe .05 toe would be best?
Feb 15, 2006 | 12:14 PM
range is -1.08 to -2.08 and nominal is -1.58 for rear camber on a stock 350z.
Feb 15, 2006 | 12:18 PM
rear toe-in is:
17": .008 to .071 inch (0.2 to 1.8 mm) and nominal is .039 in (1.0 mm)
18": .043 to .106 inch (1.1 to 2.7 mm) and nominal is .075 in (1.9 mm)
stock of course
Feb 15, 2006 | 01:21 PM
Does this mean we need even more toe-in for 19" wheels?
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
