SPL parts making solid diff bushings?
Old Apr 19, 2006 | 03:10 PM
sentry65's Avatar
sentry65
the burninator
Default SPL parts making solid diff bushings?
http://www.splparts.com/Parts/Z33/Su...nk/default.asp
sounds interesting. Anyone have any thoughts on them?
Old Apr 19, 2006 | 08:33 PM
sfarrah's Avatar
sfarrah
Default Love em!
Thoughts? Sure! I blew out my rear diff bushing at the drag strip a few months ago. It's a silicone filled bushing and Nissan doesn't sell just the bushing-they sell you an entire new subframe instead for about $300-screw that! For $109 these solid bushings from SPL are a steal and I'll never have to worry about replacing these ever again. Diff whine is somewhat audible now on decel mostly, but it's really not bad and a small price to pay in my mind for the increased traction and rigidity these provide. Wheel hop is almost completely eliminated now. I highly recommend them and am putting SPL solid subframe and diff bushings in my z32 as well.
Old Apr 20, 2006 | 01:25 PM
sentry65's Avatar
sentry65
the burninator
thanks
I'm thinking about them and am more than willing to deal with any extra noises as long as they're not rediculously loud.
what's involved with installing them? Is taking off the rear diff a long process - I'm not a mechanic, I'd have a shop do it, but only if it's just an hour or 2 of labor or so.
any other downsides? They wouldn't hurt anything would they?
how soon will these be available to buy?
is there any additional gear backlash or jerking or sudden engine braking with keeping the rear diff locked down?
Old Apr 20, 2006 | 07:47 PM
kuah@splparts's Avatar
kuah@splparts
To take off the differential you will need to remove the exhaust, unbolt the driveshaft and half-shafts, as well as disconnect the wheel speed sensors. The old bushing on the subframe would have to be cut out. It would probably be 3-4 hours of labor...
The only downside to the solid diff bushings is increased drivetrain noise, but with stock subframe bushings providing some isolation the noise level is fairly low. There is no jerking, etc.
We should have these ready in about 1-2 months... we have had other shops tell us that they have found a number of ripped stock rear diff bushings, if you ever notice black streaks on the diff housing (like in the pics) that is from a leaking rear diff bushing.
Old Apr 21, 2006 | 05:06 AM
21112's Avatar
21112
Looks good to me.
But did anyone notice what was at the top of the page?
Front camber arms with spherical bearings that have a total of 5 degrees of adjustment for only $500!!!!!
When are these things coming out, I want a set!!!!!!!!!!!!!
Old Apr 21, 2006 | 06:22 AM
Row2K's Avatar
Row2K
spl makes some ridiculously high quality parts, there was an article essentially on them and their lineup for the 300zx in sports compact car (May 2004 issue). I might scan it if i get the chance and post it up, its a great read and very informative as far as suspension work goes.
Old Apr 21, 2006 | 09:50 AM
21112's Avatar
21112
OK so on that page I notice 3 different terms:
In production, coming soon, and under development.
What do these mean in time frames?
Since it was said the solid bushings would be ready in 1-2 months, I'm guessing "in production" means 1-2 months, and therefore the front+rear diff bushings, and front camber arms will be ready in 1-2 months.
How long for the other arms which are "coming soon", or the subframe bushings which are "under development."
If the parts are THAT GOOD then I'm getting excited over here, and can't wait.
Old Apr 21, 2006 | 02:06 PM
sfarrah's Avatar
sfarrah
There have been a few articles in SCC regarding SPLParts suspension and the project 300ZX of Mike Kojima, but this is the only one I can find online.
http://www.sportcompactcarweb.com/pr...00z/index.html
Old Apr 21, 2006 | 02:42 PM
sfarrah's Avatar
sfarrah
Last time I talked to Kuah he said the camber arms were in production at the machine shop and expected to be done in a few weeks. I think a run of the bushings will be done after the camber arms are made. I have a set of the bushings so they're all spec'd out-just need to do a full production run of them.
I also have the first set of camber arms and these things are sweet. I tested them out at Motorsport Ranch in Ft Worth on the new 3.1 mile course a few weeks ago and I love them! They are definitely worth the wait. I showed them to a few other 350 owners and they were very impressed with them as well.
Old Apr 21, 2006 | 03:01 PM
sentry65's Avatar
sentry65
the burninator
are you guys ever going to offer other bushings for other parts of the suspension?
Old Apr 21, 2006 | 07:15 PM
EnthuZ's Avatar
EnthuZ
Their A-Arms look great, but I just received their hub-centric rings, and they fit like Sh*t! Not happy! I am not very happy with their clearance measurements. Maybe I got a bad set, but I have other hub-centric rings that do not require a BFH to install.
Old Apr 21, 2006 | 07:53 PM
kuah@splparts
Sorry about that EnthuZ... I made the rings fairly tight so they might need to be lightly tapped onto the wheel with a hammer, but this is the first complaint I had gotten about them. I specced these rings tighter than most aftermarket rings for two reasons, one is so the rings will stay on the wheels rather than fall off and be easily lost, the other reason is that a tight hubcentric ring will perform better..
Old Apr 21, 2006 | 07:56 PM
kuah@splparts
[QUOTE=21112]OK so on that page I notice 3 different terms:
[QUOTE]
The solid diff bushings and front camber arms are being manufactured right now, both items should be available in about 1-2 months.
As for the other items they are products that either we have not finished R&D or are slated to be developed...
Old Apr 21, 2006 | 08:01 PM
kuah@splparts
The solid diff bushings and front camber arms are our first products for the 350Z but we intend to slowly work through and address the complete suspension
Old Apr 22, 2006 | 08:17 AM
21112's Avatar
21112
[QUOTE=kuah@splparts][QUOTE=21112]OK so on that page I notice 3 different terms:
1-2 Months for the A-arms. Hmm, I can do that. If they are all that they look like they will be, I'll be picking up a pair!
Everything else is still in R+D huh? That means a very long time before we see them. Guess I'll have to pick up some JIC or Stillen rear arms.
Old Apr 22, 2006 | 04:30 PM
Asterix's Avatar
Asterix
Any chance those differential bushings will be made from something like 80A-durometer polyurethane? Even the hard 75D would be better than aluminum in my opinion. 80A would last forever and be much quieter than aluminum.
Asterix
Old Apr 22, 2006 | 05:24 PM
Julian@MRC's Avatar
Julian@MRC
We might have to run a few sets of these. Very interested,Im going to call you guys Monday!
Old Jan 10, 2008 | 05:41 AM
moog's Avatar
moog
bumping an old thread....while installing my new hubs and wheel bearings last night, I saw the differential bushing leaking. Anyone else have experience w/ the solid SPL one?
detriments of not replacing it?
Old Jan 10, 2008 | 09:25 AM
sfarrah's Avatar
sfarrah
After blowing my stock diff bushing out it was banging all over the place on accel and decel. The solid bushings definitely cured that problem. Some additional drivetrain noise in the cabin but it's not that bad in my opinion, esp if you have a full interior. I'll never have to worry about the bushings again as I replaced all three of them.
Old Jan 10, 2008 | 09:46 AM
moog's Avatar
moog
Did you drop the subframe to install?
