want to be at these alignment specs. how much to lower?
Old Apr 21, 2006 | 11:03 AM
loose_z33's Avatar
loose_z33
Default want to be at these alignment specs. how much to lower?
the car has hks hipermax rs coilovers lowered 3/4" and no other aftermarket suspension parts. i haven't gone for an alignment yet but does anyone know about how much to lower it to get at these following specs.
front:
-1.5 camber
0 toe
rear:
-2 camber
3-5mm toe in
basically, i'm trying to get to these settings without using any adjustable links and just adjusting the coilovers. i know the front toe can be adjusted but i will pony up for the spc kit if i can't get the rear toe to where i want it. any ideas on how much i should lower the car?
Old Apr 21, 2006 | 01:57 PM
1nate7's Avatar
1nate7
I think you will be pretty close where you are now. You might have to lower it another 1/4" to 1/2" or so. If you are happy with the ride height as is, I would just take it in and see where you are at.
Old Apr 21, 2006 | 02:09 PM
sfarrah's Avatar
sfarrah
Why do you want more camber in the rear than the front?
Old Apr 25, 2006 | 09:45 PM
loose_z33's Avatar
loose_z33
car is being setup for drift. i was told by a friend (formula d/d1 driver who has experience in driving s13's, fc's, fd's and z's) that this is a good starting point for alignment and will feel the best while "in drift." also, doesn't factory alignment specs call for more camber in the rear? so if i drop the car the same amount at all four corners, the rear should have more camber then the front, right?
oh btw, i see you have a connection with spl, the reason i wanted to try and get to these alignment specs without any adjustable links is because i was going to wait for their new arms. they look real good. any idea when they will be finished?
Old Apr 26, 2006 | 05:46 AM
Alberto's Avatar
Alberto
Cranky FI Owner
I would just get some kind of camber arms/toe bolts and fine tune with that. If your serious about drifting your gonna need it in the future...
Old Jun 13, 2006 | 07:27 PM
3five0_GT's Avatar
3five0_GT
Look at these.
http://www.bulletproofautomotive.com...il.php?ID=1167
Old Jun 14, 2006 | 04:58 PM
sfarrah's Avatar
sfarrah
I'm no expert at drifing(only did it once so far) but I wouldn't personally want a ton of camber in the rear as you'll wear through tires even faster than usual. I chewed up a set in a one day event with about -2 to 2.5 degrees of camber.
A friend of mine (John Yim-now drives for Enjuku) recommended a race setup for drifting as he felt it gave him the best control and balance once you break the tires free. Typical race alignment would be 2-3 degrees front camber and about half of that in the rear.
As for the SPL arms, they are still in R&D but I would guess another month or so and they should hit the market.
May 30, 2017 03:28 PM
Depravity
Oct 1, 2015 04:49 PM
